International B276
   / International B276 #1
Hiddensprings_Bill
Comox Valley. Vancouver Island
Hi
I am not sure if this is where I can find out about this tractor model. My father in law is giving it to me to use on my farm and I am trying to find out more about it. Maybe someone can point me in the right direction.
Thank you
Bill:)
   / International B276 #2
Are you sure it's not a B-275? They were build in the early 60's and were imported from abroad.
   / International B276 #6
I think that must be a UK model that was imported to Canada. I don't recall ever seeing that model in the US.
   / International B276 #8
I've seen a few up here in the north east. I know a guy who runs 2, says their good on fuel and cheap to buy, he also has a B414.
   / International B276 #9
The 276 was manufactured in England in late 1960's. BAsically a 275 with more modern hood the same as the 434 model, the only way to quickly tell the difference between the 276 & 434 is the front axle - 276 has the round section axle off the 275, and the 434 has inverted U section axle.
Not a common tractor, the 434 with extra HP was not much more money new. Apart from hood, all parts off 275 will fit and easy to find s/h
Excellent small tractor, very powerfull for size, nice to drive, independent hydraulics from engine driven pump, diff lock, good weight to power ratio for field cultivation.
Here are some pictures of it. Needs some work but I used it tonight to move a brush pile. Way better than a hand rake:)
Here are a few pics. I want to clean it up and get a new bucket for it. It used to move lots of manure so the bucket is rotten on it.
   / International B276 #12
mine is a 1969 they are the same as the 275 all that is difrent is the hood
   / International B276 #13
I have a B275, really good tractors but watch out for the hydraulic pump it tends to blow the seal on the shaft and send hydraulic oil into the engine.
There are separate oil for gear and hydraulics on these. If you are gentle with it so this is a tractor that can be handed down for generations
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
1995 John Deere 7400 (A60462)
1995 John Deere...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
