International DTA360 in frame rebuild, how bad are these sleeves?
   / International DTA360 in frame rebuild, how bad are these sleeves? #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
Due to a large amount of water in the oil, I'm doing an in frame on a DTA360. This is the first time I've ever worked on any type of sleeved diesel so, while I can see clearly that I've got cavitation and corrosion damage, I'm not sure if it's bad enough to have caused my problems or if I need to keep looking for another cause. The cylinder bores in the block are shiny and feel smooth in the area sealed by the o-rings, so I'm hopeful that it's ok. I was just hoping that when I popped these sleeves put, I'd either see a clear perforation or a torn o-ring. Without that, I'm kind of worried I may have bigger problems.
What do those of you with more experience think based on the photos?
   / International DTA360 in frame rebuild, how bad are these sleeves? #2
I would need to look closer but cavitation happens on the hot side of the sleeves or towards the inside of the block. I do see signs of it but I can't tell by the pictures if it has gotten around the o-ring.. The pitting would go around the o-ring which is where you get the loss of coolant to the base. On severe cases we have also seen it hurt the block. Cobbers have filled the cavitation with J-B weld or something similar and then dropped the sleeves back in at 180 degree's and run them off to auctions from what we have found with a few we took apart but that is not my cup of tea!
2021 FREIGHTLINER CASCADIA DAY CAB (A50046)
2021 FREIGHTLINER...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A49346)
2025 JMR 40in...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A48836)
2008 Hino 268...
2020 Dodge Grand Caravan SE Van (A48082)
2020 Dodge Grand...
2017 Ford Explorer Police SUV (A48082)
2017 Ford Explorer...
JB Pipepuller Hydraulic Culvert Puller (A49346)
JB Pipepuller...
