International McMormick B275
   / International McMormick B275 #11
thanks for your help don . now i know it is a 1959 gonna try and find a manuel for it and get the glow plugs working . it's the most miserable starting tractor i've seen . even if the long range weather forecast calls for a cloud it hates to start . This problem led to my starter problem . Thanks again
Moose,
This is very common with Internationals. The distributor cap was pourse (sp) and dampness got in and caused a problem with the points. I was told if you sealed the distributor cap it helped.
Don
i assume the 10 tooth starter is working fine and the boys from tennesee are off the hook
   / International McMormick B275 #13
i have a b275 starter , i took it apart to repair it and cant get the spring back in it properly can anyone help me
   / International McMormick B275 #14
Remember to check the glowresister on the dash aswell ! Do not heat up longer than 5 sec !
Kubota RTV1100 (RUNS) (A50775)
Kubota RTV1100...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
TAKEUCHI TL8R2 SKID STEER (A52706)
TAKEUCHI TL8R2...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
378905 (A54865)
378905 (A54865)
