Iron Worker Punch Press
   / Iron Worker Punch Press #51
When I use a friends IW, I centre punch the spot. Then raise the work against the point on the punch and press the pedal. This seems easier then trying to get the punch to come down in the right spot. Just make sure that your fingers arn't pinched!
Anyone ever tried to enlarge the holes in a mower blade using the IW? Sounds like a gunshot and the slug shoots out of there just about as quick! Scary!
   / Iron Worker Punch Press #52
That is likely because the blade is hardened, dies can also break violently trying to punch hardened steel.
Forgot to add the video in #48 shows how the arm lowers the die onto the center punch dent before you cycle the machine.
   / Iron Worker Punch Press #53
Hello, I live in Lima Peru recently bought a 60 ton ironworker and the automatic mode does not work and I can only operate in manual mode and my question is how to fix it? besides some other accessory you are needed?
thanks for your reply
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2016 24' Iron King Flatbed Trailer (A57148)
2016 24' Iron King...
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
Caterpillar 906M (A53317)
Caterpillar 906M...
