Is 1/4" drop in 10' enough.
   / Is 1/4" drop in 10' enough. #11
I would try and shoot for 1% slope, you would need 1 1/4" in 10'
   / Is 1/4" drop in 10' enough. #12
Is this clean rain water or will their be silt mixed in with it? If it's clean water, then you should be fine. If you have silt, or anything at all mixed with the water, you will have some build up. How big is the pipe? If it's too small, the build up will restrict flow. I would think four inches or bigger should work, but that depends on how dirty the water is. I've seen 12 inch culverts without enough slope in them completely plug up.
Eddie
I plan on using 4" thin wall, will drain off metal roof, approximate 2000 sq ft. Will fall into a D box with a screen . If D box overflows over, no big deal. It will just run out on ground. Actually the building is 4000 sq ft. 50'X80'. I plan on coming across 50' make a L and go 80' ft, another D box there with a T into the L. Come off the other 50 corner and T into existing line, and drop about 2' and go about 30 ' into a 500 gal tank buried. Talked to the State Soil and water district. They said if we have a 1" rain, it will produce about 8000 gal of water. (doesn't sound right to me) Seldom do we have a rain like that, but if we do and the pipe wont handle it, it can just run off. (tank certinley wont hold that much)
   / Is 1/4" drop in 10' enough. #14
4000 sq ft @ 1" of water
4000/12 = 333.33 cu ft of water.
There is 7.46 gallons of water in each cubic foot.
So, 333.33 x 7.46 = ~2500 gallons of water.
Yeah, they are a little off, but its still alot of water. It dont take much off a roof to fill a large volume.
A 1/4" average rain will overfill your 500 gallon tank.
   / Is 1/4" drop in 10' enough. #15
When I built my first house in CA, I had a straight roof edge which was 40' long. I sloped this edge at 1/8" per foot so that the gutter could be mounted just under the roof edge and still drain to one end.
This worked very well, but must be addressed at the framing stage of the building. All of my friends with building experience thought it was a crazy idea, but all were impressed with how well it worked. The only real issue was that sheet rocking the inside of that wall was unique because 1/8" per foot is 5" over 40 feet.
   / Is 1/4" drop in 10' enough. #16
...t.
I had a builder do something like that about 35 years ago, except his wasn't intentional.:laughing:
Seriously though, we had a German carpenter come in to install bi-fold doors on a closet, and he knew exactly how to do it without drawing attention to the slope.
   / Is 1/4" drop in 10' enough. #17
Now Curly, that's thinking outside the box! Slope ye whole roof so ye don't have to slope ye gutters. I'm good at coming up with hairbrained ideas, but you might have topped even me! Now, I ain't calling ye idea hairbrained, I'm calling my ideas hairbrained.
Back to the pipe drain - I'd still want to go with about 8" pipe. I was thinking clear water, and if so, 1/4" per 10' should be fine, IF pipe is layed down right. Aw, go ahead and make it 1/2" slope per 10".:laughing:
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
Duetz Power Unit (A50120)
Duetz Power Unit...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
