Is 2" Lift Worth it on '06 HPX?
   / Is 2" Lift Worth it on '06 HPX? #11
Funkster said:
I'm kind of leaning toward gettings Deere's because I would be getting a heavier strut and spring which would be better for a blade. If I use Deere's and install 27" tires on it, would I rub once I put a 72" V-blade on?
-Funkster-
I wouldn't go over 26's if it was mine. Bigger tires give you more clearance, but you sacrifice low end grunt. And with the blade you may have some rubbing.
   / Is 2" Lift Worth it on '06 HPX? #12
-Funkster-
You're speaking of two different things here. What I have isn't a lift kit but just the heavy duty strut, it inadvertantly lifts the front though because it is so much stiffer. The other lift kit is just that a kit to lift it and it's nothing more then a large spacer designed to keep the shock extended more. The spacer isn't going to help you if you have a windshield or a blade, in fact it might hurt things in the grand scheme of everything.
   / Is 2" Lift Worth it on '06 HPX? #13
I agree with that, I don't know anything about the blade but the 27's are going to weigh more, have a larger diameter, and move all the weight of the tread that extra inch farther out. Bad all around.
I'm alil confused. So he used JD's front HD strut kit?
-Funkster-
   / Is 2" Lift Worth it on '06 HPX? #15
-Funkster-
Yes. That would help you with the extra front-end weight and give you some lift~!
Thanks for clearing that up. I realize that both kits aren't the same. That's why I was leaning toward Deere's actual HD strut kit insted of just adding spacers. But from what you guys have said, I will go with 26" 589's. Looks like an awesome tire that wears fairly well considering the tread. Thanks for all the help guys!
-Funkster-
What size of rims and 26" tires should I run? I'm not sure what the factory rim size is. I was thinking that I have 24" tires on there now.
-Funkster-
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
