Is 4WD necessary?
   / Is 4WD necessary? #51
I grew up with 2WD farm tractors. Where they really sucked was deep mud with weight in the FEL bucket. Not uncommon with cattle.
With a field tractor at about 150HP a 2WD even with duals has a hard time getting the power to the ground.
And as some people said the SCUTS work better with 4WD.
OP said:
My next door neighbor farms a few hundred acres of potato and grain. He says absolutely no need for 4WD. What say you?
He is correct. Now if you want to ever want to move snow.
For me I do not care for liquid in the rear tires mainly because of nails etc.
   / Is 4WD necessary? #52
With my 6500 4wd, I was able to dig out my pond during the drought getting ready for the next rain. The 4wd was absolutely necessary to back up the grade with a full bucket. I think FEL work benefits from 4wd. Heavy uphill backing, like digging any big hole, will need 4wd.
Your 6500, just like the new 30 series and 60 series, have massive front axles and planetary gears, etc. So you can get away with this, but we actually see people breaking front axle parts if they do this a lot. What happens is when backing up hills with a big load in the bucket, your back end is light due to the angle and the load, and you are asking a front axle designed to be only assistive to move the entire tractor with a load, up a hill, probably in soft soil. If you pop the clutch carelessly, then one of several things must happen. 1) Everything holds (like on your 6500) and you just simply back up the hill but put a huge strain on the front wheel assist system 2) The front tires spin, and they won't want to with all that traction 3) the clutch slips, and that is not likely 4) you break an axle shaft or driveshaft couple or gear in the front end.
Even on a compact tractor, a rear axle might be 2" in diameter, the front will be half that. Likewise on the ring and pinion. They are designed for the rear axle to do most of the work moving the tractor.
We all do this sort of thing, but I'd recommend to folks that they be gentle when asking the front axle to take those kind of loads.
I think one huge advantage of 4wd is brakes. When going down a hill in 4wd and you hit the brakes, the front axle is mechanically connected to the brake system in a round about way and you essentially get front brakes. That is a huge advantage. It's a scary thing going down a hill with a full bucket load with a 2wd and realizing that your rear tires are barely touching and you essentially have no brakes.
   / Is 4WD necessary? #53
I agree. Dad had a Massey Industrial 35 (50HP Perkins, 6' wide bucket, big machine), it could move a barn IF you had enough traction. It rarley had enough traction even with chains, loaded tires and wheelweights. He "downsized" to a Kubota L3650 (~40HP, 4x4 with a cab and loader) and it would in most cases outwork the Massey.
Aaron Z
   / Is 4WD necessary? #54
Dave,
Loaded buckets make great drag anchors when brakes fade.;)
hugs, Brandi
   / Is 4WD necessary? #57
Until you swap ends halfway down a hill....:rolleyes:
I don't go that fast on hills.;) Besides, the only hills around here are made by me.:D A friend of mine had a JD 310TLB that didn't have any brakes. Bucket on the ground was it.:laughing:
hugs, Brandi
   / Is 4WD necessary? #58
Greetings : I've been looking far and near on the cyber treads trying to find 4wd specifics. Been a 4wd drive owner for 40 of my 60. Truck and tractor. All been get wet and lock to the toggle from the cab lock. Up to this point I have known the do's and wish I didn't do's. Well I cannot determine whether the new JD 758 4wd will be able to cut grass while turn and return on dry pavement. It appears it is full time. Any you folks have any suggestions or comments. I am posting this in a couple threads. Thanks
2706 (A51691)
2706 (A51691)
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
Fuel Tank (A50121)
Fuel Tank (A50121)
2018 JLG 1932R 19ft Electric Scissor Lift (A50322)
2018 JLG 1932R...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
