is a 31hp kioti 3054 big enough to use a westendorf ta25 loader
   / is a 31hp kioti 3054 big enough to use a westendorf ta25 loader #1
reelnative
sw florida
ford 3500,cat 416 w extenda hoe,bobcat 853,john deere110,kioti 3054, taskmaster 426e
I have a westendorf ta25 laoder it weighs in around 1200lbs with the bucket, i would like to install it on a kioti 3054, as size goes it looks like it wold fit but it weighs in about 400lbs more then the loader that the loader sales people have been trying to sell me (800LBS) my tractor weighs in around 3000lbs and with the tires loaded im guessing around 4000lbs my question is does that weight of the tractor sound stout enough for a 1200lb loader, also im getting 7gpm at 2500psi from the hydro pumb, would this work or am I looking for trouble, thanks
   / is a 31hp kioti 3054 big enough to use a westendorf ta25 loader #2
The TA-111 is the recommended fit for the tractor... The lift capacity on the TA-25 will exceed what your tractor can handle. The TA-25 will be slow with the 7 GPM as well. To answer your question direclty... YES, you are asking for trouble :)
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2006 JOHN DEERE 310SG BACKHOE (A52705)
2006 JOHN DEERE...
