Is a 486lb box blade too much for a 2320?
   / Is a 486lb box blade too much for a 2320? #11
Joseph, I have the standard GB48 box blade, and have been very happy with it so far. It is built very heavy, and does a great job when used in either forward, or reverse. If I could change one thing I would have one more notch on the scarifer blades so they could be raised higher. I often just take them out though. I have had no trouble leveling areas with heavy sod without the scarifer blades down. I have used mine in the woods on my trails ( one reason for the 48" width), and it has worked well there too. I haven't done any "huge" projects with it, but here are some pictures of some smaller areas that I have worked on / created using it.
   / Is a 486lb box blade too much for a 2320? #12
I would recommend a well built medium weight box blade. In most cases it doesn't matter how much weight your tractor can pull - it matters how much it will pull before you loose traction. if the blade is too heavy thats more material that you can't pull.
2006 Saturn Vue SUV (A55758)
2006 Saturn Vue...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2023 Jeep Gladiator Sport 4WD SUT (A55758)
2023 Jeep...
Parker 2600 Gravity Wagon (A50775)
Parker 2600...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
CASE CX57C EXCAVATOR (A52705)
CASE CX57C...
