plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,405
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm looking at a bush hog bh26 rotary cutter. It's a 3pt hitch model, single spindle, 6 foot, heavy duty cutter. Needs 45pto horsepower which is exactly what I have.
Also considering a Rhino se8a. It's a pull or semi mount, twin spindle, 8 ft medium duty cutter. Needs 45pto as a 3pt, 40hp as semi, or 30hp as pull type.
Both of these will be behind a cab model Massey 1758 tractor. I like the extra width, which means faster mowing in ideal conditions. But I definitely do not want maintenance issues from a non-HD cutter nor dealing with multiple gearboxes to possibly fail, even though they should not. I need to cut 12 acres a few times per year, mostly 2-3 foot weeds, level to moderate slope. Pasture is surrounded by forest and trees. I know a single spindle might be more maneuverable at the edges of the pasture between trees, but I think I could mow effectively with either.
Would you opt for heavy duty at narrower cut, or get 25% more cutting width at a cost of how sturdy the unit is? The twin spindle is more money, but, I learned a long time ago that you only pay for it once, but then use it many many times thereafter. So price-wise, either one is fine.
