Oil & Fuel Is all Kubota tractors use DIESEL fuel?
   / Is all Kubota tractors use DIESEL fuel? #1
JohnBoy45
Tennessee
Kubota L2800DT
Hi, I had a friend of mine tell me that Kubota use only diesel fuel in there tractors and had no gas engines. Is this true or not?
Thanks, Terry
   / Is all Kubota tractors use DIESEL fuel? #2
Terry, Kubota makes some gasoline powered lawnmowers (lawn tractors?), but I think all their tractors are diesel.
   / Is all Kubota tractors use DIESEL fuel? #3
I dunno about their tractors, but I have a 3 cyl gas powered Kubota engine in a Grasshopper ZTR mower I have. It is about the smoothest gas engine I've ever used in a mower, but it is thirsty.
   / Is all Kubota tractors use DIESEL fuel? #4
I have a Kubota ZG-23 and it has a gasoline engine in it.
   / Is all Kubota tractors use DIESEL fuel? #5
So far the friend is right... I do believe all Kubota TRACTORS use diesel.... The ZTR mowers and they may have some riders that are gas engines. The key work is TRACTRORS....
DO all Kubota tractors use DIESEL fuel?
   / Is all Kubota tractors use DIESEL fuel? #6
<font color="blue">Hi, I had a friend of mine tell me that Kubota use only diesel fuel in there tractors and had no gas engines. Is this true or not? Thanks,
Terry
</font>
<font color="black">Terry is there any reason for gasoline engines in them?</font>
   / Is all Kubota tractors use DIESEL fuel? #7
The only Kubota tractor engines that use diesel fuel are compression ignition engines, the spark ignition engines all use gasoline. If the Kubota tractor engine you are wondering about has fuel injectors and no spark plugs, you can assume that it uses diesel fuel
   / Is all Kubota tractors use DIESEL fuel? #8
LB /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif Did you say anything?
   / Is all Kubota tractors use DIESEL fuel? #9
</font><font color="blue" class="small">( LB : Did you say anything? )</font>
Yeah I did but I don't know what you did.
L O L
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
