Is Amsoil API certified?
Status
Not open for further replies.
/ Is Amsoil API certified? #21
frank_miller said:
Again run Chinamart oil in your engine and then redline/Amsoil for 10K miles and see what happens or the outcome in the UOA.
That's been done with quite successful results.
Nevemind the sludge, white smoke etc.
There isn't any.
Your API oil will fail long before the other grp 4/5 oils and that is a fact!
That is most certainly NOT a known fact.
I would not share the info since I have been there done that. Also YOU do not want that. :)
Yeah, we would like you to share the info.
Please show me where an API approved oil gets the end user ANYTHING!?????
If nothing else, it gets you warranty coverage. But it does get you something else--it gets you the oil the manufacturer recommends, in other words, the right oil.
Put it this way, have you tried these oils in your 2008 diesel? Being an API approved oil is not the same as a oil classification here nor does API integral to oil class. You are talking 2 diff things. Then again I would not buy a 2008 diesel nor a diesel at all. The fuel is too high ( $0.50 more per gallon I love that) nor being the new EPA stuff on the engines. Hay, have fun getting low mpg too.
What two different things am I talking about? If the 2008 diesel says to run API CJ-4, what should I run in it? A person would be a fool to run anything except CJ-4 in a 2006 or newer if he knows anything at all about oil.
/ Is Amsoil API certified? #22
frank_miller said:
You even said "Please don't list a bunch of UOA numbers that mean nothing to the end user"..talk about BS on your end.
That was me that said that...please at least direct your fire at the correct poster.
That is no BS...UOA numbers mean LESS than nothing. We are not keeping score by UOA numbers--we keep score by how long an engine lasts.
Show me the numbers where your non-API oil can put up superior engine longevity hours vs an API rated oil. That is the bottom line: economics, not UOA numbers.
/ Is Amsoil API certified? #23
AS I stated before show me where an Non API oil is lesser in #'s from a API cert oil...Not gonna do it CP...I have been here too long to know how you work. I have been out here long before you have been a member in 2001.
Show me side by side where a Chinamart oil will before just as good in 10,000 miles in a car/truck that normal people drive...No series 60 crap either...
Based on your lack of info, you have no used the oils in questoin. If you did, your posts would not be here.
/ Is Amsoil API certified? #24
Frank, that's not how it works. When YOU make a claim, such as:
I have utilized both (these group 4 and 5) for years and both work way over some chinamart oil too or 99% of the other API oils.
and someone challenges you to back up that statement, you can't turn it around and challenge that person to prove their oil is superior to yours. You made the claim; you back it up.
You're the one who made the claim that Amsoil/Redline is superior--back it up. No UOA crap or warm fuzzy advertising hype, either.
No, I have not used Amsoil or Redline-never said I did. This is the claim I will make: I use the API rated oil recommended by the manufacturer and have never had an oil related problem. How much more success could I have had by using Amsoil? I will go on to make this claim, too: That if there was a measurable savings in the operation of engines using Amsoil or Redline, the secret would be out and truck fleets would all be using it.
/ Is Amsoil API certified? #25
My apologies, Frank. I guess I saw that you had something like 15 posts and made an assumption that you were a newby. My Bad.
Guess you didn't have much to contribute until now?
/ Is Amsoil API certified? #26
I have been on here for years....Long before you, cowboydoc etc...
/ Is Amsoil API certified? #27
Can I jump in ?? I use non API certified group 4 (POA) Amsoil. I guess my engine will soon self destruct. I wish I had used A GROUP 3 API certified mineral oil. My engine would have lasted longer:(
/ Is Amsoil API certified? #28
Frank, Let me see if I understand this API thing. I make oil & I'm going to put some real good stuff in the oil. API says we will not certify your oil cause it's got too much of the good stuff added & we only allow a certian amount of that good stuff.Never mind that more of the good stuff makes the oil better
/ Is Amsoil API certified? #29
FAQ on Motor Oils
This FAQ about motor oils is in two main sections. The first section, on motor oils, thier use, properties and limitations was authored by a member of the Antique Tractor mailing list. His name is Guy Burnham and I have included his email address after the first section.
The second section was authored by Ed Hackett, and is version 1.2 of his OIL FAQ as posted to Usenet. He was, and still is I think, a chemical engineer for the University of Nevada's Research Facility.
If you have any questions about either section, I suggest that you contact these folks directly.
I found this is very informative and without any of the the "posturing without facts" that often accompany topics such as motor oils. The Antique Tractor Forum did not author this nor can it, it's manager, spon ser or members be reponsible for it's contents. The information is provided as is: Feel free to interpret is as you see fit. The authors have provided this information as friendly advise and observations and do not proclaim to be experts in the area, have full knowledge of your particular circumstances, nor intend to keep the information current. They inform you to solicit expert opinion for confirmation before following thier advise or using this information.
Please enjoy,
SWY 3-14-95
SECTION 1
This may get a little long, but I want to share with you some of the things I learned in my locomotive days. I worked with the engineers for Sulzer, a Swiss manufacturer of diesel engines, with Mobil and with a couple of filter companies, one of which made most of the "house brand" filters including OEM filters for GM and Chrysler.
Oil performs several functions:
* Lubrication
* Corrosion protection
* Cooling
* Contaminant transfer
What I learned is that there are numerous tradeoffs made in all these areas and it is useful to look at some of them.
Some of these areas are in conflict. You can count on regular, automotive oils to be a good compromise for use in modern automotive engines. If your use is otherwise, it helps to understand what they did.
DETERGENT/NONDETERGENT- Detergent additives are just surfactants which lower the surface tension and allow small particles to remain in suspension more easily. This is to transfer contaminates to the filter so they can be removed. You do not want deposits to form throughout the engine because that makes them hard to remove and insulates the passages so that the oil can't remove and equalize the heat. The base viscosity is increased somewhat by other additives to compenste for lower surface tension. Back when overhaul intervals were shorter, The deposits would get cleaned up periodicaly before they got too bad. I wouldn't use nondetergent in an engine with modern parts.
There is little problem with detergent oils unless they are subjected to very high temps or pressures or used in hydraulic systems. High temp and pressure can convert some additives to shellac like compounds that are really hard to remove. I think the diesel rated versions are less prone to this but it's not a big deal in most applications. Also, there may be extra foaming if air can get introduced somewhere. I had trouble with my JD M with detergent oil in the lift system.
One problem you can have as mentioned by others is adding detergent oil to an engine that has a huge amount of deposits in it. As the detergent softens these deposits, there is a risk of a chunk coming loose and blocking something. The risk is real but then if you have this much stuff in there, you have a time bomb waiting to go off anyway because a big temperature swing can trigger the same thing. The right answer is to tear it down and clean it up. My answer is to run detergent oil, at moderate load, and change oil and filter frequently for 3 or 4 changes and hope for the best.
OIL GRADE- The numbers, 30 weight, 15-30 weight, etc. relate to the viscosity of the oil. Viscosity is a measure of the "shear strength" of a thin layer of oil. This is important because of the way a plain bearing works. It is not the oil pressure generated by the oil pump that keeps the crank separated from the crank bearings (for example). Rather, it is a local area of higher pressure generated by the shearing action of the parts moving relative to each other. This "hydro-dynamic bearing" layer is what resists the forces of pistons and so on. If the oil is too thick, this layer will not form fully or oil may not even get into the space to start with. Too thin and the layer will not be thick enough to prevent contact at the high spots.
For an engine used fairly little, when oil changes are infrequent, multi-viscosity oils are important so that lubrication is adequate in either winter or summer. However time, temp, and chemicals, break down the additives that control the viscosity in these oils so that it changes over time. One reason they recommend at least annual changes. If the tractor is only used in a narrow temperature range, then a single weight oil would last longer without change since it theoretically contains less additives. However, oil companies may use the same base stock and add stuff to get various single grades, so I wouldn't count on more stability over time.
CORROSION- An important function of modern oils is corrosion inhibiting. That is because there are so many different metals in a modern engine. If the Ph is too far out of whack, galvanic corrosion can eat things up. There is a microscopic variation of this called "fretting corrosion" that can get to parts that are in contact but move very little under quite a bit of pressure. That is what gives the odd stain patterns on shafts and surfaces that are together a long time. The Ph of the oil is really affected by the water it picks up because the water will react with gasses to form acids. That is why lots of short trips are bad, lots of blowby and gasses and lots of moisture that does not have time to be driven out.
Oil starts out a bit on the basic side and gets more acid over time. I think they assume that most cars get a fair number of short trips. This is a bit of a problem for a tractor that does not get used too much since a basic Ph will corrode aluminum and an acid will corrode zinc and iron. Ideally you could keep "half worn" oil all the time but you can't. I use this as a justification for not changing oil too frequently.
FILTRATION- This a place where a lot of compromises are made and specs are pretty vague. In general, filters are rated by the pore size in microns. However, this is not a absolute limit due to the construction of the filter. The rating indicates that the filter will trap 90% of particles above that size. What they don't tell you is what is the biggest particle size it will pass. Good quality (expensive) media with a 20 micron rating will pass some particles up to 45 microns. Fuel filters have about an 8 micron rating with a 25 micron max. The tradeoff here is flow rate. The higher the filter efficiency, the lower the flow. A good "trick" some companies use for marketing is to go to a smaller rating paper that has bigger max pore size to get back some flow rate. They advertize "We have 16 microns and they have only 20" but they don't tell you they will pass a bunch of 60 micron stuff that "they" would trap. Interestingly, there is a standard "test dirt" you can buy for these tests that has a known distribution of particle sizes.
Engines are pretty tolerant of particles up to about 30-35 microns so the small end of the scale is really not what you worry about. Most filters actually improve in efficiency with use. That is because the big holes get bridged over and the surface becomes more uniform. The best quality filters have a micron rating that is fairly high, say around 28 but is very uniform pore size. This paper improves pretty fast to around an 18 actual perfomance and stays that way a long time. A bad filter on the other hand has small pores so it tests well when new but a wide variation in sizes. The small pores tend to plug over in use and the big holes open up with the added flow through them. This results in a worsening efficiency condition. A filter that plugs too fast can also rupture or cause the unit to "bypass" the filter so that there is no filtering at all.
Unfortunately, there is little you or I can tell about filters until it is too late. If you could get them, you could compare the manufacturers graph of efficiency, flow loss and max particle size over time (actually volume filtered). The best have a broad time in the middle range with high efficiency and low flow loss. The manufacturers have these, but I have never seen such graphs available at the retailer. The best bet is to buy good quality brand name filters. The highest price ones are probably no better and the lowest price ones may or not be the same. It isn't worth the $3 difference to find out. Never use fuel filters for lube oil, by the way. They will plug too fast and it is overkill. If a tractor is not used very much, say just for shows, I would consider changing oil each year and filter every other time to limit the amount of big particles getting through. This would not be true if you are "cleaning up" a dirty engine with detergent oil.
OIL TESTING - I should mention that a lot of truckers etc use a testing service to keep track of their engines. It is a little expensive for us commoners but might be useful in some cases. The oil is sampled and sent to a lab. They can test it for metal content and for Ph and lubricity. More money buys more detail. Some people have used the technique to determine change interval though I doubt it is worth it for th at unless you are talking a lot of oil (locomotives hold ~250 gallons in the pan). A better use would be to assess the state of an engine that is in question. High readings of iron indicate a wearing bore or cam/liter, aluminum is piston maybe bearing, lead is bearings, etc.
Normally it is good to have periodic samples and spot the trend but in the case of a new find you could:
* Sample the oil when you change it. Good reading = no problem. Moderate = check again. High = open it up an d have a look.
* If the first reading was moderate, sample again after ~50 hours on new oil. Good reading= OK, you bought a good one but they didn't change oil often enough. Moderate reading = There is a problem and you will have to decide whether to find it now or wait for it to get severe. High = The problem is getting worse, fix it now.
Guy Burnham
guy@boi.hp.com
SECTION 2
More Than You Ever Wanted to Know About Motor Oil
By Ed Hackett edh@maxey.unr.edu
Edits:
* v1.0 First there was 1.0. Before that there was darkness.
* v1.1 Change in description of viscosity.
* v1.2 Updated info on AMSOIL (courtesy of Morgan McArthur mgn@inel.gov)
Choosing the best motor oil is a topic that comes up frequently in discussions between motoheads, whether they are talking about motorcycle s or cars. The following article is intended to help you make a choice based on more than the advertising hype.
Oil companies provide data on their oils most often referred to as "typical inspection data". This is an average of the actual physical and a few common chemical properties of their oils. This information is available to the public through their distributors or by writing or calling the company directly. I have compiled a list of the most popular, premium oils so that a ready comparison can be made. If your favorite oil is not on the list get the data from the distributor and use what I have as a data base.
This article is going to look at six of the most important properties of a motor oil readily available to the public: viscosity, viscosity index (VI), flash point, pour point, % sulfated ash, and % zinc.
Viscosity is a measure of the "flowability" of an oil. More specifically, it is the property of an oil to develop and maintain a certain amount of shearing stress dependent on flow, and then to offer continued resistance to flow. Thicker oils generally have a higher viscosity, and thinner oils a lower viscosity. This is the most important property for an engine. An oil with too low a viscosity can shear and lose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to "real" viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at 0 F and is therefore suitable for Winter use.
Multi viscosity oils work like this: Polymers are added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
Multi viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter base your decision on the lowest temperature you will encounter, in the summer, the highest temperature you expect. The polymers can shear and burn forming deposits that can cause ring sticking and other problems. 10W-40 and 5W-30 require a lot of polymers (synthetics excluded) to achieve that range. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best.
Very few manufactures recommend 10W-40 any more, and some threaten to void warranties if it is used. It was not included in this article for that reason. 20W-50 is the same 30 point spread, but because it starts with a heavier base it requires less viscosity index improvers (polymers) to do the job. AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Mobil 1 uses no viscosity improvers in their 5W-30, and I assume the new 10W-30. Follow your manufacturer's recommendations as to which weights are appropriate for your vehicle.
Viscosity Index is an empirical number indicating the rate o f change in viscosity of an oil within a given temperature range. Higher numbers indicate a low change, lower numbers indicate a relatively large change. The higher the number the better. This is one major property of an oil that keeps your bearings happy. These numbers can only be compared within a viscosity range. It is not an indication of how well the oil resists thermal breakdown.
Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendency for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption. Flash point is in degrees F.
Pour point is 5 degrees F above the point at which a chilled oil shows no movement at the surface for 5 seconds when inclined. This measur ement is especially important for oils used in the winter. A borderline pumping temperature is given by some manufacturers. This is the temperature at which the oil will pump and maintain adequate oil pressure. This was not given by a lot of the manufacturers, but seems to be about 20 degrees F above the pour point. The lower the pour point the better. Pour point is in degrees F.
% sulfated ash is how much solid material is left when the oil burns. A high ash content will tend to form more sludge and deposits in the engine. Low ash content also seems to promote long valve life. Look for oils with a low ash content.
% zinc is the amount of zinc used as an extreme pressure, anti-wear additive. The zinc is only used when there is actual metal to metal contact in the engine. Hopefully the oil will do its job and this will rarely occur, but if it does, the zinc compounds react with the metal to prevent scuffing and wear. A level of .11% is enough to protect an automobile engine for the extended oil drain interval, under normal use. Those of you with high revving, air cooled motorcycles or turbo charged cars or bikes might want to look at the oils with the higher zinc content. More doesn't give you better protection, it gives you longer protection if the rate of metal to metal contact is abnormally high. High zinc content can lead to deposit formation and plug fouling.
The Data: Listed alphabetically --- indicates the data was not available -69
Brand VI Flash Pour % Ash % Zinc Brand VI Flash Pour % Ash % Zinc
20W-50 20W-40
AMSOIL (old) 136 482 -38 <.5 --- AMSOIL 124 500 -49 --- ---
AMSOIL (new) 157 507 -44 --- --- Castrol Multi-Grade 110 440 -15 .85 .12
Castrol GTX 122 440 -15 .85 .12 Quaker State 121 415 -15 .9 ---
Exxon High Performance 119 419 -13 .70 .11 15W-50
Havoline Formula 3 125 465 -30 1.0 --- Chevron 204 415 -18 .96 .11
Kendall GT-1 129 390 -25 1.0 .16 Mobil 1 170 470 -55 --- ---
Pennzoil GT Perf. 120 460 -10 .9 --- Mystic JT8 144 420 -20 1.7 .15
Quaker State Dlx. 155 430 -25 .9 --- Red Line 152 503 -49 --- ---
Red Line 150 503 -49 --- --- 5W-50
Shell Truck Guard 130 450 -15 1.0 .15 Castrol Syntec 180 437 -45 1.2 .10
Spectro Golden 4 174 440 -35 --- .15 Quaker State Synquest 173 457 -76 --- ---
Spectro Golden M.G. 174 440 -35 --- .13 Pennzoil Performax 176 --- --- ---
Unocal 121 432 -11 .74 .12 5W-40
Valvoline All Climate 125 430 -10 1.0 .11 Havoline 170 450 -40 1.4 ---
Valvoline Turbo 140 440 -10 .99 .13 10W-30
Valvoline Race 140 425 -10 1.2 .20 AMSOIL (old) 142 480 -70 <.5 ---
Valvoline Synthetic 146 465 -40 <1.5 .12 AMSOIL (new) 162 520 -76 --- ---
15W-40 Castrol GTX 140 415 -33 .85 .12
AMSOIL (old) 135 460 -38 <.5 --- Chevron Supreme 150 401 -26 .96 .11
AMSOIL (new) 164 462 -49 --- --- Exxon Superflo Hi Perf 135 392 -22 .70 .11
Castrol 134 415 -15 1.3 .14 Exxon Superflo Supreme 133 400 -31 .85 .13
Chevron Delo 400 136 421 -27 1.0 --- Havoline Formula 3 139 430 -30 1.0 ---
Exxon XD3 --- 417 -11 .9 .14 Kendall GT-1 139 390 -25 1.0 .16
Exxon XD3 Extra 135 399 -11 .95 .13 Mobil 1 160 450 -65 --- ---
Kendall GT-1 135 410 -25 1.0 .16 Pennzoil PLZ Turbo 140 410 -27 1.0 ---
Mystic JT8 142 440 -20 1.7 .15 Quaker State 156 410 -30 .9 ---
Red Line 149 495 -40 --- --- Red Line 139 475 -40 --- ---
Shell Rotella w/XLA 146 410 -25 1.0 .13 Shell Fire and Ice 155 410 -35 .9 .12
Valvoline All Fleet 140 --- -10 1.0 .15 Shell Super 2000 155 410 -35 1.0 .13
Valvoline Turbo 140 420 -10 .99 .13 Shell Truck Guard 155 405 -35 1.0 .15
5W-30 Spectro Golden M.G. 175 405 -40 --- ---
AMSOIL (old) 168 480 -76 <.5 --- Unocal Super 153 428 -33 .92 .12
AMSOIL (new) 186 464 -76 --- --- Valvoline All Climate 130 410 -26 1.0 .11
Castrol GTX 156 400 -35 .80 .12 Valvoline Turbo 135 410 -26 .99 .13
Chevron Supreme 202? 354 -46 .96 .11 Valvoline Race< /TD> 130 410 -26 1.2 .20
Chevron Supreme Synt. 165 446 -72 1.1 .12 Valvoline Synthetic 140 450 -40 <1.5 .12
Exxon Superflow HP 148 392 -22 .70 .11
Havoline Formula 3 158 420 -40 1.0 ---
Mystic JT8 161 390 -25 .95 .1
Quaker State 165 405 -35 .9 ---
Red Line 151 455 -49 --- ---
Shell Fire and Ice 167 405 -35 .9 .12
Unocal 151 414 -33 .81 .12
Valvoline All Climate 135 405 -40 1.0 .11
Valvol ine Turbo 158 405 -40 .99 .13
Valvoline Synthetic 160 435 -40 <1.5 .12
All of the oils above meet current SG/CD ratings and all vehicle manufacture's warranty requirements in the proper viscosity. All are "good enough", but those with the better numbers are icing on the cake.
The synthetics offer the only truly significant differences, due to their superior high temperature oxidation resistance, high film strength, very low tendency to form deposits, stable viscosity base, and low temperature flow characteristics. Synthetics are superior lubricants compared to traditional petroleum oils. You will have to decide if their high cost is justified in your application.
The extended oil drain intervals given by the vehicle manufacturers (typically 7500 miles) and synthetic oil companies (up to 25,000 miles) are for what is called normal service. Normal service is defined as the engine at normal operating temperature, at highway speeds, and in a dust free environment. Stop and go, city driving, trips of less than 10 miles, or extreme heat or cold puts the oil change interval into the severe service category, which is 3000 miles for most vehicles. Synthetics can be run two to three times the mileage of petroleum oils with no problems. They do not react to combustion and combustion by-products to the extent that the dead dinosaur juice does. The longer drain intervals possible help take the bite out of the higher cost of the synthetics. If your car or bike is still under warranty you will have to stick to the recommended drain intervals. These are set for petroleum oils and the manufacturers make no official allowance for the use of synthetics.
Oil additives should not be used. The oil companies have gone to great lengths to develop an additive package that meets the vehicle's requirements. Some of these additives are synergistic, that is the effect of two additives together is greater than the effect of each acting separately. If you add anything to the oil you may upset this balance and prevent the oil from performing to specification.
The numbers above are not, by any means, all there is to determining what makes a top quality oil. The exact base stock used, the type, quality, and quantity of additives used are very important. The given data combined with the manufacturer's claims, your personal experience, and the reputation of the oil among others who use it should help you make an informed choice. Return to the A.T.I.S FAQs page
Return to the A.T.I.S home page
/ Is Amsoil API certified? #30
That is just something I found on the net.
I hope it helps.
/ Is Amsoil API certified? #31
Georgia Boy,I can't read all of that . I'm from the south :p
Why don't we all just start using Castrol ??:confused: It's more than just a motor oil :rolleyes:
Ya know,
It's liquid engineering:eek:
/ Is Amsoil API certified? #34
You're not the only one
they ( castrol ) sell alot of oil I mean @#$%^&
do they ( castrol) even know about group 4- 5 oils ??
Aren't they the ones that do the hydrocracking thing with oil ??
/ Is Amsoil API certified? #35
Not only is it good but the price is average and
if they sell oil they sell castrol. Easy to find.
/ Is Amsoil API certified? #36
Now, I know it's not API certified ,but I think I'll stick with Amsoil. I like the numbers
There are several brands that are hydrocracked and hydrotreated. Some are severly hydrocracked and treated and some are moderatley hydrocracked and treated, etc. Some basestocks are so severly hydrocracked and hydrotreated that their basestocks are pharmaceutically pure. I have seen a demonstration where a pharmaceutically pure basestock was added to a lobster tank, and then the next evening the lobsters were taken out, boiled, and eaten.
/ Is Amsoil API certified? #38
DieselPower said:
Here you go, an API licensed oil that is performing quite superbly in a short haul FLD 120 road tractor. And by the way, this diesel engine gets on average 6.5 MPG pulling a loaded logging trailer 6 days a week through the mountains. Let's see a gas engine that can do that.
And by the way, the little API logo has nothing to do with Chinamart as you put it.
I can't comment on the wear numbers here since I'm not at all familiar with UOA's from heavy duty diesels. But I will say that oil seems to have very healthy additive package. It even has some moly which is somewhat rare in an HDMO. And the air filtration is great on that engine. People with cars would love to see those silicon numbers over that interval.
Not related to your post DP, but to address the API argument that this thread has become -
I don't see the reason for the dispute. It's pretty simple really. Selecting an oil that's API certified to the spec recommended by your engine manufacturer will pretty much guarantee you a suitable lubricant.
Will some oils just barely meet the spec. and others surpass it substantially? Sure. Will some non API oils show better results that the recommend API certified oil? Of course it's possible. It's also possible to choose one that really doesn't work well in a given application, or is just an inferior product.
So the API certification is somewhat "oil for dummies" though I don't mean that in a bad way. It's great way to make sure your lubricant meets a suitable minimum standard. Other oils, API and non API may show much better performance in a given application. But the API spec will at least give you a minimum performance level and keep your engine warranty in tact...
Well Put... Couldn't have said it better myself. If your warranty has expired and your feeling like taking a chance on an oil that has not been tested and certified by API, by all means your free to put whatever you want in your engine. You can run vegetable oil for all i care. If you'd rather go with something that you know works and has credentials and test results to back it up rather than taking one of your buddies word on it then the API symbol means something. I myself am not rich enough to gamble with my diesel engine. I feel better knowing rather than wondering and hoping for something to work. But like i said, i dont have the luxury of being able to experiment with with a high dollar engine. Others may. I would think that any oil that meets or exceeds the API standards would want to be certified by them. They have nothing to lose by having it certified. If anything they would sell more. I've met tons of people who wont buy an oil that ISN'T API certified, i've never met single person who wont buy an oil because it IS API certified. With all that said, there might be oils out there that arent API certified that exceed the certifications. But given that it is seen as somewhat of a bench mark i am skeptical of an oil that claims to exceed the certifications but will not have it API certified.
/ Is Amsoil API certified? #40
saparks10 and JSharp - Both well put and couldn't have said it better myself.
JSharp - He does have a very good Silicon count on the UOA. It's probably due to him running a double filter element. Last time I talked to him he said his outer filter was getting changed about every month and a half. The inner one last well over a year. Considering he is in a very dirty and dusty environment I to would be tickled pink with those numbers.
Status
