Is cylinder repair a do it your self job?
   / Is cylinder repair a do it your self job? #11
ultrarunner said:
Last week I noticed the left angle cylinder on my D3 Dozer is leaking... not much, but 2 drops a minute.
My questions are:
1. Is this a do-it-yourself project?
2. What is the conventional wisdom on repair vs replace?
3. Any idea about how much this will cost for parts vs repair?
4. Would I be better off going to an independent or my CAT Dealer?
This is a pretty straitghtforward, simple repair. The trick is getting it apart. I've never worked on Cat, so there's probably gonna be a few variations that I haven't seen before. From what I've read in your posts, you have more then enough skill and ability to do this.
Cost of a rebuild kit will run you from $20 to several hundred. I found a local guy who will sell me just the seals that I need, so that's where I can do it for $20 or so. If I go to the dealer, I have to buy a kit with allot of stuff in there that I don't need and just through away. Lately, the dealer has started replacing their pistons, so I have to buy a new piston AND the rebuild kit. This is where it gets into the several hundred dollar range.
Twice now, I've had to take the cylinder in to have it done. One time, I just couldn't get it apart. Nothing I had would do it, and I spent allot of time trying. The second time was to have the inside of the case rebored. It turned out that somebody had used bolts that were too long on one of the brackets that thread into the side of the cylinder. Those bolts had dented the case.
The other couple dozen times I've rebuilt cylinders, have all gone pretty easily. Here is a thread that I posted awhile ago on one of those rebuilds.
http://www.tractorbynet.com/forums/parts-repairs/69127-rebuilding-cylinder-my-hoe-stick.html
Eddie
   / Is cylinder repair a do it your self job? #12
I am not much of a mechanic but my manufacturer convinced me I could do my own cylinders. For my application, I simply unhooked one end of the cylinder rod, and grabbed hold of the end of the cylinder that unscrews with a large pipe wrench and reefed on it, and reefed on it, and reefed on it....
Finally I took the other end off and went to the local machine shop. I witnessed the largest pipe wrench I have ever seen in my life along with a serious blow torch and some fantastic australian cursing (our little town has an aussie for a metal worker) to take the cylnders apart. And putting them back together was no easy task as the tube tolerances are very tight...
Carl
   / Is cylinder repair a do it your self job? #13
I would say it's a DIY project provided:
1 You can afford the down time to work on it yourself.
2. The rod does not need replacing.
3. You can actually get the cylinder apart (as many have stated)
Keep in mind that once the cylinder is apart, the Rod will have to be separated from the internal piston in order to replace the rod seals. Might as well replace the piston wipers & O-rings as well.
On my Komatsu Dozer there were two cylinder rods heavily pitted & seals leaking pretty bad. I removed the cylinders and took them to a hydraulic repair shop where they disassembled the cylinders, cut the clevis off the rod, Honed & polished the ID, then machined and threaded new metric rods, welded the clevis back on, replaced all seals, re-painted with matching color, then tested. Two completely rebuilt cylinders as good as or better than new cost a bundle, but cheap compared to replacing with two new cylinders.
I'm glad I had it done by someone who does this for a living, they did a great job, their turnaround time was 3 days.
Larry
   / Is cylinder repair a do it your self job? #14
If you do it yourself, you will appreciate the labor that goes into repairing one of these things and won't complain so much about the cost of having someone else do it, if and when you do carry one in for repairs.
   / Is cylinder repair a do it your self job? #15
Anybody know how to get a "snap wire" type of retainer out of the end of a cylinder on a Kubota BF350 loader? Tried budging it loose or out of the groove by tapping a needle under one end of it. No luck. Tried tapping the seal ring further into the cylinder in case that is what is required to make enough clearance to get the snap wire out of the groove, but it didn't budge, so maybe that isn't the way to go either. Any ideas?
   / Is cylinder repair a do it your self job? #16
Maybe you could get under the tip of the wire ring with a dental pick or the similar o-ring tool?
   / Is cylinder repair a do it your self job? #17
Post a pic dude. That way it's easier to see exactly what you're dealing with.
   / Is cylinder repair a do it your self job? #18
Something like a pick hook might work. I thought most of these wire retainers had a bend at the end to grasp with pliars or a loop somewhere you could pry against.
I had a cylinder on a Terramite utility backhoe professionally rebuilt and it started leaking shortly after the reinstall. Tore it down and found a burr that the "pro" had missed. Put it back together. Won't bother with him again.
I think it's a messy job. Patience and a lot of clean rags help. For something as large as a cylinder on a dozer, I'd lean towards a professional rebuild, but not necessarily at the CAT dealer. I'd be asking for quotes up front to compare the costs.
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
2012 CAT 316EL (A55272)
2012 CAT 316EL...
1617 (A58375)
1617 (A58375)
2017 Liebherr L566 X Power Articulating Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel (A59076)
2017 Liebherr L566...
Giyi Backhoe (A57149)
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
