Is Headland Piston Better Than Standard Piston??
   / Is Headland Piston Better Than Standard Piston?? #1
wjb-49
Lawsonville, North Carolina
LS MT573-CPS, Ford 4610
In working on my Ford 4610 today (Reference this thread) we found that it has Headland pistons rather than Standard pistons. A ring kit for Headland pistons costs almost three times the cost of standard ring kits - a kit is for only one piston.
The technician told me a new standard piston with rings would cost less than only the Headland rings.
That brings me to two questions:
  1. Are the different types of pistons interchangeable?
  2. Is the quality\performance of the Headland pistons worth the extra expense?
Thanks for any thoughts or experiences.
   / Is Headland Piston Better Than Standard Piston?? #2
I'm not a diesel mechanic, but I've rebuilt enough gas engines to have learned my lesson around mixing and matching pistons and other parts in the rotating assembly... Unless the replacement piston is exactly the same weight and size as the one that's busted, it's better to either stick with what's in there, or just replace all of them as a set. Same goes for the rings. The last thing you need is to have pulled the rod and piston, and then have to re-do the whole thing six months or a year later when the vibration or piston slap tears things up.
Re: Is Headland Piston Better Than Standard Piston?? . . . Update.
Well . . . After what I learned today this has become a moot question. A local Ford/New Holland parts dept. associate told me that Headland pistons were discontinued by New Holland.:frown: I ordered standard pistons and rings and they should arrive tomorrow morning.
I will update my original thread (see above) with a report on how they improve how my tractor runs.
mahlers, Thanks for the good advice!
   / Is Headland Piston Better Than Standard Piston?? #4
that is the way to go get as far away from the headland pistons as possible
Do they cause more problems than standard pistons? The guy at Ford/New Holland parts dept. said they were originally thought to be better than standard ones.
   / Is Headland Piston Better Than Standard Piston?? #6
Headland pistons used originally in Ford tractors (like your 4610) were great for performance...until they blew up. The process used to attach the headland to the top of the piston fatigued and the top of the piston crumbled causing lots of damage. The bonding method was improved and lasted quite awhile longer. The problem with all of the headland styles was that the top ring was more sensitive to dirt and therefore would fail more often than standard piston/rings. Of course, maintenance has something to be factored in to any engine failure due to dirt.
Ford was trying to squeeze as much HP out of their engines as possible and headlands were actually used with a turbocharger to achieve phenomenal performance in certain models.
Thanks for the Headland piston history - that explains why they were discontinued. I will pass this along to my technician, who said he had rebuilt a number of 4610s and had not seen the Headland pistons before. I am always amazed and grateful for the extensive knowledge of TBN members!
11L-15 TIRE W/ 6 LUG ALUMINUM RIM (A52708)
11L-15 TIRE W/ 6...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2006 International 7400 T/A Altec AM55 55ft. Material Handling Bucket Truck (A55973)
2006 International...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
1768 (A58375)
1768 (A58375)
