Buying Advice Is hydralic gpm good enough on mx5100
   / Is hydralic gpm good enough on mx5100 #1
culvers
newton,wi
MX5100
I have been reading n learning from tbn for a couple of months.Narrowed my choice of tractors down too mx5100 kubota.My concern is im doing mainly grapple work on 200 acres of woods and it seems like the mx is much lower in hydralic capacity compared too other tractors in its class.Want to hear if it is going too run grapple as good as other with 16+gpm v.s. 9.6gpm.Any advice would be appreciated.Thanks
   / Is hydralic gpm good enough on mx5100 #2
Flow in GPM provides the operating speed while pressure PSI provides the force.
With the same grapple the 16+ GPM will operate faster. Now the question becomes how fast do you want the grapple to operate?
   / Is hydralic gpm good enough on mx5100 #3
   / Is hydralic gpm good enough on mx5100 #4
Would you please tell us what 50hp tractor you have seen that has a 16gpm implement flow rate. :confused: I think that you are looking at combined steering and implement flow rates which is a common mistake. Normally you have to get up into the 75hp + to have those flow rates. You will be fine with the MX5100 ;)
   / Is hydralic gpm good enough on mx5100 #5
Yep, example of my Kioti has a listed flow rate of 16.5GPM but the actual flow rate at the remote is just 10GPM.. I think manufactures use the higher number just to confuse newbies when comparing tractors. As far as grapple operation, what I have heard people complain about is the grapple operating too fast, and having to put flow restrictions in line or use smaller hydraulic lines in and attempt to slow down the operation of the grapple.. You are not going to have a problem with your MX5100 operating your grapple.
James K0UA
   / Is hydralic gpm good enough on mx5100 #6
As others note, you shouldn't have a problem with hydraulic flow. But make sure you match the size of grapple to the size of the tractor. It's possible to mount a grapple that's so big and heavy you don't have sufficient true payload lifting capacity left over. So resist any Tim the Toolman maximum overkill impulses! Welcome to TBN!
   / Is hydralic gpm good enough on mx5100 #7
the 8540 has a 17gmp pump on it that the tractor i would look at
   / Is hydralic gpm good enough on mx5100 #9
I have an mx5100 and I have a grapple. I use it hard and it has plenty of hydraulic speed. I don't believe you'll have any issues.
   / Is hydralic gpm good enough on mx5100 #10
Just purchased a MX5100 HST with root grapple. Great machine for that type of work. You will have no problems with the hydraulic flow. Just make sure you have the dealer put a box blade on the 3pt hitch and try to raise it slowly. Make sure it doesn't have the mysterious "jerky 3pt hitch disease" before you buy it. Especially if you intend to use the tractor with a box blade. Some seem to be smooth operating while others are jerky.
(2) 9.5-16 TIRES & RIMS (A50460)
(2) 9.5-16 TIRES &...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A48081)
2009 Hino 268...
John Deere 835M (A50490)
John Deere 835M...
2022 CATERPILLAR 279D3 SKID STEER (A50458)
2022 CATERPILLAR...
UNUSED SWICT 72" SKID STEER QUICK ATTACH BUCKET (A50460)
UNUSED SWICT 72"...
1990 Ford Ranger 4x4 Pickup Truck, VIN # 1FTCR11TXLUC19238 (A48836)
1990 Ford Ranger...
