Is it a pain to raise trailer GVW?
   / Is it a pain to raise trailer GVW? #31
Magnets are fine for interstate commerce. IDK why they wouldn't be for NY. Just because you were fined for it doesn't really mean it was law either.
   / Is it a pain to raise trailer GVW? #32
There are trailer fabricators whom build trailers from scratch, and are registered, licensed by the state/DOT whom produce weight certified trailers . I would reccommend you contact one of them to evaluate your trailer and determine if the trailer can be modified to the higher load limit. Then with the fabrication/ mods done, a new title from the fabricator can be issued. The mods may be few and cheap, or might be too extensive and costly to make it worthwhile. A good fabricator can add length, increase frame strength and load limit, change out axles and issue a new manufacturers title and spec sheet for your trailer to be registered as new with the new specs. Racemaster trailers in Oswego may be able to help you, or a shop in your area that is a licensed trailer fabricator.
After I figured tounge weight, I'm fine. I had the trailer custom built. It is MORE than capable of handling a couple more tons, BUT, I wanted it titled and registered at 10,000 so NY doesn't get my $$$.
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
2014 Nissan Pathfinder SUV (A53117)
2014 Nissan...
