Is it OK for the system to go to relief all the time?
   / Is it OK for the system to go to relief all the time? #11
Greg:
I had a slow afternoon and my daughter tried to teach me Powerpoint last weekend, so I doodled on your project in Powerpoint. The site will not let me upload Powerpoint directly, so I scanned the result and attached it (I hope) in pdf. I just looked and it blocked out the "balloon" that identifies the existing line from pump to three point hitch (dotted line) which is the one you are splicing into.
Here are my thoughts, based on my very limited experience. Your pump output of 3.5gpm suggests a small tractor. My Kubota B2400 HST is very small (24hp, they claim) and has about 4.7gpm pump output. Of that 4.7 gpm, about 1.7 gpm is priority flow to the steering and the remaining 3.0gpm flows first to the front end loader power beyond valve and then to the three point hitch. Nothing moves very fast, including the steering, but they move about as fast as I do, which is nothing a young man would brag about, but suits me just fine.
I recommend you consider a "variable" priority flow control valve because it allows you to adjust the amount of priority flow by must moving a lever on the valve. They don't cost any more than the "adjustable" priority flow control valve, and are much more convenient to adjust. There may be times when you want more or less flow to the steering, and the variable flow valve lets you fiddle with it as much as you want.
The second issue is the pressure relief for the power steering. The Prince variable flow control valves can be had with an internal pressure relief valve, but then the excess flow port must be connected to the reservoir rather than the downstream FEL valve, which makes the valve unsuitable for your purpose.
A separate PRV for the power steering circuit downstream of the flow control valve controlled flow doesn't add much cost or plumbing. Prince stand-alone PRVs are available in a 500-1500 psi range, while the built in PRV in the "adjustable" Prince flow divider may have a 1500-3000 range unless you special order it.
The third issue is the system PRV, meaning a PRV just downstream of the pump output, so that any blockage anywhere in the system will not deadhead the pump. Be sure your tractor has a system PRV and that you do not splice your steering and FEL in upstream of it.
Fourth, I don't think the 1000 psi PRV in the pump circuit will open unless you turn the steering wheel to full lock. Here is why. Suppose you have a load on the FEL that requires 2000 psi in the EF circuit to lift it. As the pressure builds in the EF circuit, flow will try to increase in the CF circuit above its setting (say 1gpm). The priority flow control valve will close the orifice in the controlled flow circuit as needed to keep the CF at 1gpm regardless of the pressure in the CF circuit. The pressure at the CF port will be only return line pressure because the 1gpm flows (relatively) unimpeded through the open center steering valve and on to the reservoir.
Fifth, your FEL control valve should have power beyond to avoid excessive back pressure on the spool o-rings from the downstream TPH. Most two spool loader valves have power beyond, though you may have to spend an extra $30 for the power beyond sleeve that activates this feature.
Lastly, a 0-3000psi pressure gauge costs less than $20 and the tee to insert it in costs less than $5. That $25 installation in the steering circuit just prior to the steering valve will let you set the steering PRV to the exact setting you choose. It is not likely that it will come from Prince set at exactly the 1000psi you desire.
It sounds like a fun project, though I predict you will be surprized at the total cost (hoses, fittings, etc. will be a large percentage of the total) and the complexity of the plumbing.
Gobble Gobble.
  • Greg's steering.pdf
Thanks again JJ. And I am sorry to keep bothering you all
But now I am puzzled about the plumbing of a priority divider
I know that the IN port is where the high pressure line from my pump would go. The Controlled Flow Out from the Priority Flow device will go to the IN of my steering pump.
The Excess Flow Out from the Flow device will continue down line to my 3 point hitch or loader (I dont have a loader yet so it would go to my 3 point hitch...and it does have a relief valve on it.)
What I am unsure of is where I would take the OUT from my steering valve to.
Farmerford, I just saw your drawing..WOW, THANKS!
I will study it tonight. Lots of learning to do.
OK, I drew something up by hand. FarmerFord inspired me.
Is a relief right after the pump really necessary if the Priority Flow Divider, loader valve and the Hitch lift valve all have relief?
  • hydraulic_drawing.pdf
   / Is it OK for the system to go to relief all the time? #15
No. If the FEL valve has a relief, that should take care of the rest of the system.
I would not use QD's in a hyd circuit before the first valve with a relief.
A relief valve across the pump is an extra protection, should any valve get blocked.
Your diagram looks correct.
   / Is it OK for the system to go to relief all the time? #16
Greg:
First, JJ gets up too early (or stays up too late) for a man of his age.
Second, his white hair and beard fit my image of an Old Testament prophet; Jeremiah, perhaps.
Third, see my thoughts on your drawing, attached.
Fourth, where do you live?
Fifth, Happy Thanksgiving to all!
Chuck
  • gregs drawing markup.pdf
The instructions for the Prince Priority Flow Divider says that the relief must be plumbed to the tank. I am not sure how this is accomplished. Doesnt the relief go through the Excess Flow Port?
If it does, that would this render that port useless if it has to go back to the tank and not the loader circuit.
https://www.surpluscenter.com/Instruct/I9-4158-15.pdf
Greg
   / Is it OK for the system to go to relief all the time? #18
The relief output can go back to tank through it's own hose, or be teed into another return hose, as long as the back pressure is low.
Is the relief output right at the adjustable valve.
   / Is it OK for the system to go to relief all the time? #20
The large hex plug is the relief, and the relief port.
The relief port is a 3/8 port on the valve. In the drawing, there are 4 ports. The 3/8 port goes to tank.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2020 Hyundai Santa Fe (A56859)
2020 Hyundai Santa...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
