Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #151
Depends on the station and the area. We can get 91/93 with or without ethanol same for 87 octane.
If I could get 87without I personally would not waste money on the premium because it will serve you no better that the regular and in 99% of the uses of gas it will actually perform less efficiently than the regular. I have done extensive dyno testing back when I was racing and with almost every engine we tested fuels with they all made more power and better power curves with regular than they did with premium or race fuel. I still laugh when people pay the extra for it when they are driving anything less than a full on sports car that calls for it because of a high performance engine that will never end up in your lawn mower or tiller or even the family sedan.
   / Is it time for a gasoline engine tractor? #152
You really don't understand carbs very well do You? Carb technology is much better than that but to match fuel injection it becomes cost prohibitive not impossible.
My daughter's Honda Accord had "smart carburetor". It was a maintenance nightmare. There were about 20 vacuum tubes connected to it. Even the dealer couldn't fix it.
   / Is it time for a gasoline engine tractor? #153
I agree 93 octane isn't needed for most. I don't mind ethanol and run E10 in everything except my 69 Mach 1. Even my 1971 F350 gets 87 e10 because I don't see a need to pay more for the 87 E0.
   / Is it time for a gasoline engine tractor? #154
Small air cooled engines in chain saws and snowmobiles are better operated on 91 or 94 octane to reduce detonation . For the little teeny tiny bit more $ for premium it avoids burning a hole through a piston due to detonation.
   / Is it time for a gasoline engine tractor? #155
Oh, rider for sure. ;) I don't feel up to push mowing anymore. :)
Last push mower I bought was 98.. it had a throttle.. havn't looked at one since, so they might well be startup and take off ready. I'll take your word for it.
as for small moter vs large motor... I think you are missing what I said. there are plenty of GAS tractors that were running less HP engines than many rider lawnmowers are now.. if the small engine in a lawnmower doesn't have to meet an emission standard, why would it need to meet the standard in a tractor application? My current 12.5 hp rider mower is MORE hp than a few of my cultivating tractors.. think about it...
I disagree with your disagremment on gasser lie expectancy. ;)
looking at tractors and cars.. which, given is not straight apples to apples .. Look at gas cars from 70's 100k and the car was ready to be a toaster.
I think much of it is design and materials. Throw away engine designs coupled with alumin alloys, and non peak rated hp output put lots of stress on engines made smaller... that wore out and were junked instead of rebuilt.. vs a heavier beefier design meant to have liners punched out, bearings rolled in and crank polished and rings replaced then ready to go another couple decades. IE.. their constant load design was reflected in their materials. So.. 30's-60's were robust... 70-80's got puny.. now here we are with gas engines that don't need tune ups till past 100k.
I'd deffinately call that a bell. high, low, high...
Is your MTD a push mower or a rider? I was thinking push mowers, I have not seen a push mower in a while that didn't just have an on and off switch. Not saying I am an expert but just showing my point that small gas engines to meet regulations are specially setup to work at rated and not much else. The carburetors are adjusted for rated and not meant to be variable like the old days. Lots of smaller motors now are going EFI just to meet the standards.
I think you misunderstood what I said, current tier 4 regulations break "Nonroad Spark-Ignition Engines 19 Kilowatts and Below" down into different levels based on engine size, year, EPA phase, and if it is hand held or not. They also break out things like marine generators. What I was meaning is that a small lawnmower motor doesn't have to meet the same standards that a larger motor you would find in a tractor does.
I would disagree with your life expectancy, I would say gassers have been on a steady climb since day one but in the 60s diesels overtook gas and stayed ahead but have been losing ground to the gas motors.
I don't disagree that gas tractors can do the work, I am merely talking about the differences between gas and diesel engines and why diesel gained favor a long time ago.
In 1990 my father bought an 8200 Heston windrower and got it with a gas engine. It was one of 6 built (or that is what we were told) that year and I think it was the next year that they dropped the gas option. Just not enough demand.
   / Is it time for a gasoline engine tractor? #156
   / Is it time for a gasoline engine tractor? #157
Farm tractors all ran similar or identical rpms for the gas and diesel versions.
Just as a point Yanmar has made a 3600rpm single cyclinder air cooled diesel for decades. is it a lousy performer ?
Maybee not related.. but in 58 or so when ford introduced it's diesel prior models using the red tiger engines.. the lineup looked like this.
gas version
134ci gas or 172ci diesel.
144ci diesel, 172ci diesel.
the diesel were lower hp than their gas counterparts... heck.. the 134 / 144 weren't even the same CI...
   / Is it time for a gasoline engine tractor? #158
because the Semi truck is a HD applications with a duty cycle near full rpm and full power. The CUT, forklift, manlift, car and light truck are light duty application at part throttle and part load. I am being to think that some people don't know the difference ?
You clearly don't understand what a duty cycle is. CUT aren't cars or light trucks, or forklifts, or man lifts, and comparing them is pointless.
What CUT or SCUT manufacturer publishes a limit to the amount of time their machine can run at full rated power? None. Any diesel rated for continuous full power is NOT a light duty application.
   / Is it time for a gasoline engine tractor? #159
Typical use of CUT tractors is light duty . Even if it was medium or heavy duty so what . Rare is the CUT that is used more than 200hrs a year.
   / Is it time for a gasoline engine tractor? #160
If crude oil stays cheap this will lower the cost of ULSD and keep it about par with gasoline . Of course if crude returns to the prices of the past decade, ULSD will once again be 20%-30% more $$$ than gasoline.
Why do you insist on repeating things that are wrong? The national average price for regular unleaded and diesel are within a penny or two of one another, and have been that way for a year.
Crude price isn't the only factor in the price of fuel, and a rise in crude price alone won't make diesel instantly more expensive than unleaded. Diesel refineries had to repay billions in upgrades to comply with ULSD standards....that's paid off. Demand for diesel has been at unprecedented rates. Other countries are starting to refine diesel, and that will increase worldwide supply, which will keep the price low.
In short, pretty much everything other than your personal opinion points to diesel continuing to be similar priced to unleaded, and lower in many places. This station isn't losing money, and I'm pretty sure they don't have a sweetheart deal on the price of diesel:
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
