is its possible for a hydraulic valve to stick
   / is its possible for a hydraulic valve to stick #11
Back when I was a teenager on the farm, I had a hydraulic valve stick on our tractor just from heat. It was a very hot day and I was cultivating, and I was making several very short back and forth swaths in one particular area where I had to lift the cultivator up (then drop it again) several times in succession, only a few seconds between operations. Towards the end of the dinking around, the control lever started to become more and more difficult to move, almost to the point of totally seizing. Once I got out into the open again and the valve had time to cool down somewhat, it was back to normal. Never happened before that and never happened again after. Could it have been debris? Possible, but it didn't seem to fit the cause as well as over heating did.
sounds like that's mostly likely the spool getting hot, and starting to loose clearance in the bore... one it cold it had room to move again.
2015 Ford F-250 Reading Service Truck (A56858)
2015 Ford F-250...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
Rome TCW-20-24 (A57148)
Rome TCW-20-24...
Bolt Cutters (A57454)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2015 Ford F-550 Mason Dump Truck (A56858)
2015 Ford F-550...
