is my splitter's pump bad?
   / is my splitter's pump bad?
yes, i was able to turn it by hand. now i know what parts i need, but i'm not sure which spider material i should buy. any ideas what material it should be made from? SOX rubber, urethane?
   / is my splitter's pump bad? #13
Personally, I'd just buy a complete coupling, both halves and the spiders and be done with it. They aren't much, maybe 15 bucks.
I'd be willing to bet it's a urethane spider. That type of coupling provides a degree of shock absorbtion and allows for misalignment to a degree.
I have 5 or 6 on the shelf in the shop. All my spray rigs use them.
ok, just got home with a complete new coupling and spider for about $19. gonna throw it on later and hope that's all there is to it. thanks again for all your help.
   / is my splitter's pump bad? #15
Something caused that other coupling to fail, so check the alignment of the pump shaft and the motor shaft and tighten the bolts equally.
After you start the engine, place you hand on the coupler housing and feel for any vibration.
its all together and seems to be working well! time to start splitting again. thanks again for all the help and advise!!
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
202482 (A54757)
202482 (A54757)
