Only 1 person speeks about the C (combustion) spec and the S (spark) spec off oil ! That is what you have to look at ! Early oils can be a CB....CC ....CD spec . The furter in the alphbet the better the oil ae a CI oil will fulfil all the specs off all oil from the start to the CI but not the CG ae that will be better than the CF.Yes, you can use diesel engine oils in gasoline engines. No problem whatsoever.
Ralph
I use Rotella T6 in everything except my daughters Corolla. I stay with the recommended 0-20 since it’s still under warranty.
Now for then next stepThat is our choice since it is good for every engine we own and none are under warranty and have never learned about a better motor oil choice.
And just how does a person arbitrarily arrive at that conclusion? :confused3:A 10w30 oil is probably what plain old 30w oil was years ago before the change to rating it multigrade.
The reply was this:
"In reference to your query, please see below message from Shell Technical Team.
Thank you.
Hope this helps. For further assistance, please respond back to this email or call our Customer Service hotline and you will be assisted as soon as possible.
Sincerely,
Estefanie Rigor
Consumer Customer Service Team
Dear Sir,
No Rotella Oils are recommended for use in gasoline vehicles with catalytic converters.
Regards,
Shell Technical"
For those who use Rotella in gas engines in cars and trucks...
I use Rotella T6 in everything except my daughters Corolla. I stay with the recommended 0-20 since it痴 still under warranty.
