Is pump working correctly
   / Is pump working correctly
Thanks guys for the suggestions. I have many things to try. Will update.
   / Is pump working correctly #12
Timing is everything, and there are two sources of timing miscues for most diesels: the cam timing (skipped chain, broken gear) and the injection timing (could be shaft, gear, or chain, assuming not electronic injection!)
So your pump could be fine, but not spurting at the proper moment, or the injection system could be dandy, but the valves could possibly be out of time, in which case things still wouldn't work. If ether doesn't work, I'm a bit suspect about the pump being bad, as we've always gotten a few chugs out of starting fluid!
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
