Is there a “Power Trac Secret Society Club?”
   / Is there a “Power Trac Secret Society Club?” #1
joshlee
Platinum Member
Beaver Springs, PA
Power Trac PT1430 Year made 2016
Years ago when I first bought my Power Trac a guy was telling me that they have a secret hidden warehouse in Tazewell that is full of new and never before seen Power Trac attachments and tractors, that are exclusive only to members of this underground club.
Have you guys ever heard of this before? Maybe some of you are members? There may be a 33rd degree member on here for all I know.
  • Good Post
Reactions: Lnk
   / Is there a “Power Trac Secret Society Club?” #2
   / Is there a “Power Trac Secret Society Club?” #4
The this thing about the UPTC is...
...we don't talk about UPTC. :cool:
This is of course the only correct answer..
Which is also why, if such a club did exist, and I’m not saying it does,
That membership and the exclusive products that alleged members have access too, remain elusive
I’m thinking about what the hazing rituals might be for initiation into the club?
1. You have to go out into a snowstorm with the snowblower attachment on, only clothing on being shorts. The time one can endure this is to what level you start out in this secret society UPTC.
2. The next step would be to see how long one can stick his hand on a PT 425 muffler after mowing the grass for two hours. This is where you would get your brand.
   / Is there a “Power Trac Secret Society Club?” #7
Better yet, make someone try and start a Robbins Subaru below 20 degrees Fahrenheit, that's good for some laughs!
I remember when I had mine it wouldn’t start below something like 37°, and it was even inside of a garage.
  • Good Post
Reactions: Lnk
   / Is there a “Power Trac Secret Society Club?” #10
I have the Robin 22 hp in mine and it has been starting in an unheated garage when outside temp was 8 below zero. No heat or any other help .
   / Is there a “Power Trac Secret Society Club?” #11
It is really not bad if you know how to use a choke. It seems with todays cars, trucks and fuel injected lawn equipment, a lot of people don't know what the other knob is for.
   / Is there a “Power Trac Secret Society Club?” #12
I thought the other knob was there to hold your beer for you. :unsure: :giggle:
   / Is there a “Power Trac Secret Society Club?” #13
I know how to use a choke, seems the spark is not very hot on the 425 with Robin engine. They make a hotter coil to increase the spark, but just may live with the limitation. Once I finish my building it lives in. The wood stove will be run to warm things up prior to use. But, if you are so sure you can start my 425 when below 30, I will be more than happy to learn from you what I am doing wrong.
   / Is there a “Power Trac Secret Society Club?” #14
FWIW I went out and test started mine ahead of a big snow that we're expecting. I have the Koehler CH-750 in mine. Kinda cantankerous to start when subzero cold, but is was a fairly balmy 25F out. Got it started OK then just kinda seemed to run poorly. Fiddled with levers, ran the hydraulic around, nothing seemed to help. Then I noticed that I had mentally reversed which lever was the choke and which was the throttle like a doofus... 🦃
All good after that! So I think the PTSC secret handshake should involve knowing which lever is which. 🤝
   / Is there a “Power Trac Secret Society Club?” #15
Mine are labeled, not sure what year mine is as I bought it used. The left is throttle and the right is chock. Down being max throttle and max closed choke. Funny, today mine started right up, of course it was 60f today.
   / Is there a “Power Trac Secret Society Club?” #16
My choke and throttle cables are sitting on my back steps, so I'll be shoveling tomorrow. 😬
   / Is there a “Power Trac Secret Society Club?” #17
If it was cold enough to snow here, and we got enough that needed to be moved, regardless where my cables are, I would be shoveling. My PT does not like the cold. 5040 doesn't live close enough to get it started for me either.
Thankfully, we don't get any snow worth mentioning.
   / Is there a “Power Trac Secret Society Club?” #18
The coldest I can remember starting my 2001 PT425 with the Kohler CH25 is around -5F. I gave it a quick shot of starting fluid and off she went.
My cables got frozen up with rust or dirt in late December. So I removed them and took them inside and spent a couple weeks with them hanging in my basement while lube slowly crept into them. Then is got cold enough to that I don't want to put them back on until spring. We're supposed to get around a foot of snow today, so I may regret that, but really, all I have to do is drive the Suburban up and down the drive 5-6 times and it'll pack it all down.
The 425 I had with the Subaru engine was a major disappointment when I found out how hard it is to start in cold weather. Looking back now, what I would’ve done was had some kind of a heater on it 24/7.
   / Is there a “Power Trac Secret Society Club?” #20
I have yet to have a task that I absolutely needed the 425. I have 2 other tractors, none with fel mounted. I have a fel for the Deutz, but it needs some work on the cylinders, I will get to it in due time. Most of my tasks can be handles with three point attachments. I will eventually solve the cold start problem. It may take an engine replacement. I will just schedule PT tasks around the warmer weather. Maybe living in an enclosed building will help it too. I knew about this problem when I bought it, so not disappointed. When I solve it, I will post the solution.
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
(1) 30"X7' ADS DRAIN PIPE (A60432)
(1) 30"X7' ADS...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A59228)
1994 Generac...
2019 CATERPILLAR 246D3 SKID STEER (A60429)
2019 CATERPILLAR...
