PineRidge said:
This sounds like a good, cheap solution to me.
Not only cheap, but very workable.
There's problems with just about every method mentioned except for one idea. .... The chain hanging from the draft arms that can be backed under the tongue and used to lift the tongue to the height of a fixed ball/pin hitch/ect.
3-point "stay bars" would require loosening bolts to adjust as the hitch was raised and lowered. The bolts would need to be tightened each time you hitched the spreader. Not exactly difficult, but time wasted none the less. Stay bars have been around since the 3-point hitch was invented. But... They just never did really catch on. Adjustable, just not EASILY and QUICKLY adjustable sometimes. Another downfall to the stay bars? They will bend when force is applied UPWARDS. They will support weight just fine. Just hope the tongue weight doesn't go "negative" on a down hill or with the back end of the spreader loaded heavier than the front. (Don't ask me how I know.... Or why the set of stay bars that came new with dads Ferguson F-40 look like pretzles)
3-point A-frame or mounted reciever has a flaw too. Depending on how the load is balanced, or the grade on which you're operating (driving down-hill with a load
), the hitch may raise up on its own. (No down pressure)
The BEST solution is 2 tractors. One loader, one pulling the spreader, which should be hooked to the fixed drawbar.
I've hauled manure before with one tractor to do the entire job. My spreader had a 3" pipe welded to the tongue that took the place of a tongue jack. When hitched to my fixed drawbar, it was over 6" off the ground. When I pulled up to the barn with an empty spreader, I'd just pull the pin and drive away. After using the tractor to load the spreader, I'd back up to it, with draft arms lowered. That would let the chain I had from arm to arm drag the ground. After I was nearly to the hitch, I'd raise the draft arms. Then I'd move the hitch around to line things up, and drop the pin. (A ball would work much the same way.
For those who want cheap, all this would cost is a short piece of pipe (or a couple wood blocks?) and a 3' long piece of chain.
There's no hydraulic hoses to hook up. There's nothing much to buy. And most importantly, not much to do at each hook/unhook cycle. When you're hauling manure is NOT the time when you want to be climbing all over the tractor tightening bolts and playing with difficult hitch's.
