Is there a block drain plug on the B7800?
   / Is there a block drain plug on the B7800? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
In changing the anti-freeze in my B7800 I can't seem to find a block drain plug and the owner's manual has no mention of it. Just the radiator drain that doesn't seem to do a thorough job. That seems odd. Anyone know if there is a block drain plug on the B7800?
   / Is there a block drain plug on the B7800? #2
I have changed the coolant 3 times now, every 2 years, and drained the system via the factory supplied drain valve. Once the radiator cap is off, I got the system completely drained, every time. Remember the drain valve is located lower than the lowest part of the engine cooling system... So this should work. I have not seen any other drain cock on the cylinder block, only the nylon one on the coolant hose.
Hope this helps you Sixdogs.
   / Is there a block drain plug on the B7800? #3
On my m8540 the block drain is almost behind the water separator down below it. Mines just a bolt with a compression washer. it makes a **** of a mess if you pull it
Thanks... Dan W has it right and as I think about it realize that the radiator plug is the lowest spot and will indeed drain if on level ground. I was on a slight slope of the barn pad but can fix that tomorrow.
And xring, I used to have a larger Kubota and was able to find a petcock with hose attachment that allowed me to drain the anti freeze without the huge mess it used to be.
Thank you.
(2) 445/50R22.5 Road Tractor Tires on Rims (A43476)
(2) 445/50R22.5...
2016 Ford E-350 Econoline Cutaway Service Van (A46683)
2016 Ford E-350...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
2014 Kenworth T800 4 Axle Dump (A43476)
2014 Kenworth T800...
Ez-Go Electric Golf Cart (A47307)
Ez-Go Electric...
2008 Ford E-250 Cargo Van (A46683)
2008 Ford E-250...
