Is there a cable bury attachment?
   / Is there a cable bury attachment? #21
At the least make sure you get direct bury rated Ethernet, even if you put it in conduit. Normal indoor rated Ethernet can have a porous jackets. And conduits will get wet due to condensation if not leaks. Same goes for fiber, although it's intrinsically less susceptible to moisture than copper.
both normal and direct bury cabling have the same outer PVC jacket.
direct bury cable differs in that there is an additional internal filler -- a gel-like substance that is intended to help prevent corrosion of a metallic conductor in the event that the outer PVC jacket is damaged (e.g. a small nick or stretch/radius fracture) during installation of the cable below ground or in a conduit.
you are correct that any underground conduit will eventually fill with water due to condensation. you can use NASA-grade solvent welds on your underground NM (PVC) conduit joints but the condensation due to the lower soil temperature will eventually fill the conduit with water unless the ends of the conduit are hermetically sealed (which is all but impossible). for this reason, the NEC rates underground conduit as a "wet location" and requires specific types of insulation (e.g. THWN) for AC wiring.
multi-mode and single-mode fiber optic cables are both marginally affected by water absorption in the plastic fiber (MM) and/or plastic cladding (SM), however at the distances most residential folks are going to encounter (< 2Km) the added attenuation due to water absorption will not be a significant factor in the optical link budget.
wrooster
2023 Zimmerman 4000 XL (A53472)
2023 Zimmerman...
LMC LOT NUMBER 129 (A53084)
LMC LOT NUMBER 129...
CAT 279D (A50123)
CAT 279D (A50123)
2025 CFG Industrial SSECAG-Y (A50123)
2025 CFG...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2018 Great Dane Freedom LT 102"x48' Flatbed Trailer (A50123)
2018 Great Dane...
