Is this a Ford 4000 TLB?
   / Is this a Ford 4000 TLB? #1
DavesTractor
Elite Member
Red Bluff, CA
Changes often!
I just took in trade a nice older TLB. I don't know much about these older Fords, so I could use some help. I looked at "The Vintage Ford Tractor Resource" on the web to try to decipher the model/VIN number, but I still wasn't able to figure it out. The numbers stamped on the pad behind and above the starter are 41301 and then 28569. The later number has a diamond before and after it which I think means it has cast iron cylinder sleeves. The loader is a 720 and the hoe is a 723. It has power steering and is gas. It has a PTO but no three-point. The hoe/loader is sub frame. It was blue early in it's life.
Any help would be appreciated.
Another picture
And another
different angle this time....
dash area....
   / Is this a Ford 4000 TLB? #6
Dave
I'm not sure what your's is , but I've attached a few pictures of Ford 4000's that I found on the web. Picture is of 63 Ford 4000
Andy
   / Is this a Ford 4000 TLB? #7
64 this time
   / Is this a Ford 4000 TLB? #8
Diesel version
   / Is this a Ford 4000 TLB? #9
is it posible that it might be a case?
just a quess /forums/images/graemlins/cool.gif
   / Is this a Ford 4000 TLB? #10
Might be a conversion. Hoe looks like a Wain Roy. Probably has a hydraulic pump on the crank snout...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2019 Infiniti QX60 SUV (A51694)
2019 Infiniti QX60...
