Is this laser what I need
   / Is this laser what I need #11
I'm afraid that I got a laser just like that at Costco and had to return it due to it being out of level by over an inch in 50'. Also you will have to get one with a detector for the rod to use it outside ... or buy a separate detector.
I got a Dewalt thru Amazon for $300. Then I had to buy a tripod and rod separately. I'm extremely happy with my package.
A spirit level is a good alternative but only if you have the luxury of having a helper every single time you want to do any leveling.
As stated earlier, check the calibration (if the unit has instructions to do so ... my cheapo did not). Checking "calibration" is fine to a point however, is no substitute for always checking between 2 points of know elevation each time you setup.
I received the laser yesterday and it was just as pictured and not damaged in transit. Now for the bad news. As others have stated, it will not work very good outdoors /forums/images/graemlins/frown.gif . It would be fine for ceiling type work, floor lines, setting tile, etc, anything INDOORS. I have looked for a laser detector and rod, but not much luck finding one. Lesson learned, you can't buy a 1000 dollar laser for under a 100 bucks and expect the same results. Thanks to all who posted.
   / Is this laser what I need #13
FYI, I found a detector at Lowe's for a bit over $100 ... seems to be the going price on the net as well. Seems like they and Home Depot have rods as well. Not totally sure. A rod isn't positively necessary. You could just buy a cheap tape measure, cut it off and tack it to a stick or even just mark a stick by hand. Whether inside or outside just make sure the laser (or level) is actually throwing an accurite line.
Cheers!
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
Hydraulic Grapple Bucket (A47384)
Hydraulic Grapple...
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
23222 (A50323)
23222 (A50323)
