Iseki Land Leader 275
   / Iseki Land Leader 275 #1
DanTractorMan
I have a local dealer selling a relatively new Iseki tractor with "Land Leader 275" on each fender. Does anyone know what this is?
   / Iseki Land Leader 275 #2
It should be a TA Series model... early 1990's The "Land Hope" name was used on the TU Series in the late 1980's... Not sure why some have it and some do not. Mine has the "LandLeader" name as well and is a TA 210. The TA 275 should be 27 HP at the PTO and should be a 4WD. Right? It should be "similar" to the Massey Ferguson 1165 series that was out in the 1990 - 1994 period.
If you go on Iron.com and search I think there was an MF 1165 up in Canada you could compare....
The frame size was the same for all TA Series.. only differences were, either 2WD or 4WD and size of engine, wheels/tires... I do not believe any were Hydro all 16 Speed Shuttle Shift. /forums/images/graemlins/grin.gif
   / Iseki Land Leader 275 #3
I also have a TA210 as my personal tractor. It's a great tractor. I also have the TA210-TA230 parts manual on CD in PDF format if you need one.
   / Iseki Land Leader 275 #4
My personal tractor is an Iseki TA270. There were TAXX0 models then TAXX2 then TAXX5 and I have a TA207 coming in that is the newest version of the TA I have had. The TA275 should be a very good model to have. I have no complaints with my TA270. I just fit a mid mount loader for a Massey MF1250 on it with minor adjustments.
   / Iseki Land Leader 275 #5
Yes....
I sent you a PM on this......... Thanks /forums/images/graemlins/grin.gif
   / Iseki Land Leader 275 #6
I have an Iseki 230. I need the user manual and the part manual. Great if you could mail me that!
   / Iseki Land Leader 275 #7
I also have an ISEKI TA 230 Land Leader. Im looking for any manuals for this tractor. Great if anyone could sent me by e-mail. Thank you.
Mlesko
   / Iseki Land Leader 275 #8
I have a Iseki Landleader 275, it has low oil pressure and needing to get it rebuilt. Do you know where I can get the parts?
   / Iseki Land Leader 275 #9
I can supply parts from US & Japanese sources.
   / Iseki Land Leader 275 #10
How can i contact you on parts and price of what I will need to rebuild my tractor?
Wacker Neuson G25 20kW Towable Diesel Generator (A51691)
Wacker Neuson G25...
(2) KUBOTA TRACTOR WEIGHTS (A51247)
(2) KUBOTA TRACTOR...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
UNUSED TOPCAT ECSSSTG200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
