Iseki TX1510 (Mitsubishi K3B) valve adjustment
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #1
Ernie-32
Southern France
Iseki TX1510F, Case IH 845A
For those of you looking ahead for information before starting this type of maintenance, every 400h, here's my experience;
Access to the adjusters is really easy, although it helps to also unwind the rubbers of the cylinderheadcover as if they were nuts, in stead of forcing them off.
Next issue is locating the marker on the crankshaft pulley that shows Cyl1 (front) is at TopDeadCenter if opposite on engine markpoint. I looked and looked and looked again, but did not succeed to find any marking on the pulley! Access to the pulley and the marker on the engine is really limited.
Next challange is overturning the engine slowly with pressure building up in cylinders. So I removed all 3 glowplugs (once disconnected I measured them at 1 Ohm resistance each, which is perfect) and lifted the rear axel while blocking one rear wheel and shifting into 3rd (high) gear to use the other wheel to push the cranckshaft around. This works pretty well.
Unfortunatley thanks to the pre-burn chamber where each glowplug and injector reside, it is not possible to let some sort of soft plastic or wooden pin down in the opening of the glowplug to determine the top position of the piston. See drawing. Taking out the injectors could have helped, but since my tractor runs very well, I don't want to disturb what seems okay.
So I watched for each set of valves to be shut and felt if both had about their maximum play. Then measured that play (.20mm still has movement, .25mm none, .30mm does not enter) for each cylinder and to my big surprise this 40 year old tractor had perfectly adjusted valves!
Reassembled the head cover (no need to replace the joint) and put back the glowplugs adding a little graphite on their threads.
Maybe someday someone somewhere finds this info usefull.
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #2
K3B eh?
This is all I have on the engine.
  • MITSUBISHI ENGINE K3B K3D K3E PARTS MANUAL MM201421.pdf
  • MITSUBISHI ENGINE K3A K3B K3C K3D K3E SERVICE MANUAL.pdf
K3B 0.849L is the number I found on my engine on the side (not near injection pump like pdf describes, but I can't look now. Just reinstalled cover plate and lots of work to do).
Thanks for the PDFs
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #5
I can also confirm the engine is K3B fitted in my TX2160,DSC02562 by chrismac2012, on Flickr
DSC02577 by chrismac2012, on Flickr
Have you ever looked at the PDF doc found here then?
I wish there was a document to know what Iseki's have Mitsubishi engines in them.
Thanks for that nice background info, it indeed confirms the use of the K3B engine in Iseki TX1510F as in my case. Also great to see the confirmation the TX2160 is as good as the same tractor, mostly sold in France and differs mostly from the Tx1500-series in wheelsizes ? At least that's what I know so far, I'm clearly not an expert :)
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #7
Thanks for the PDFs
The engine numbers are beside the injection pump, they are covered in paint and need a rub with emery paper or a wire brush to reveal them, I thought I had a photo when I pulled my engines apart but after searching through my photos I unfortunately cant see it, I have put an arrow on my picture hopefully in the correct location, where the number is, its on a machined surface just above the governor cover. Hope thats of some help.
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #8
No I have not, I opened them briefly yesterday but never gave them an in depth look.
   / Iseki TX1510 (Mitsubishi K3B) valve adjustment #9
Not only does the PDF give you the history of Mitsubishi & Satoh tractors, it's a huge look up table of the various models sharing engines and in what tractor generation series.
The last page is critical. It has all of the Mitsubishi after market parts places to network. A huge plus when finding the rare item part needed.
Yes this is indeed the place the manual indicates and I had looked already several times. Now I took another effort in discovering it and INDEED THERE IT IS !!! It is only visible when the light is at an angle and taking a photo of it, is nearly impossible :)
Would have been nice if "1850" (it looks like 9850 but that is some damage) did also say anything about the manufacturing date. So this engine is the 850th K3B 0.849L-model produced in Kyoto by Mitsubishi.
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2004 Ford F-250 (A53422)
2004 Ford F-250...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
