ISO general advice on adding remotes to '97 Kubota 4850
   / ISO general advice on adding remotes to '97 Kubota 4850
Thanks everyone, this is exactly the sort of information I was needing. Links to products have been very helpful as well.
I'll post pictures of my loader valve and where the lines connect to the main body, just in case that helps.
Any thoughts on whether to go with high dollar Parker flat face couplers or is there a decent cheaper brand?
   / ISO general advice on adding remotes to '97 Kubota 4850 #12
I tried some disconnect under pressure flat face couplers and it takes so much force to connect that they're unusable, at least by me. I switched to Parker ag connectors which are much easier to use. If you don't tip the female end down after disconnecting you won't loose much oil. I keep a rag on the tractor to catch and clean up the oil.
   / ISO general advice on adding remotes to '97 Kubota 4850 #13
Good advise already and I cant add much. But there are some links in my signature to my diverer and remotes install. Dont know if the older kubotas have that similar hydraulic manifold and routing, but you may find some useful info in there
NEW FRONTIER 53" 4N1 BUCKET (A52708)
NEW FRONTIER 53"...
207279 (A52708)
207279 (A52708)
2020 Global R3 Air Street Sweeper (A56858)
2020 Global R3 Air...
1987 Chevrolet R3500 (A57148)
1987 Chevrolet...
2016 Morbark Chipper (A55787)
2016 Morbark...
HAULING 4 1/2' X 8' S/A TRAILER (A52708)
HAULING 4 1/2' X...
