OP
captbluewater
Thanks for all your suggestions. My first thought was to hire a dozer with a winch but I figured it would cost a minimum $2000 to have one delivered and use for day. The road to the back of my property are narrow and have deep ruts from last years rainy season. My truck is a Mitsubishi that is to light and I do not want to put any of my friends vehicles in harms way. I remember watching an episode of Dirty Jobs where they pulled a tank out of a ditch. So since I had already bought a winch I figured using the large tree up the hill to attach some snatch blocks and 4 part the winch and use the power of tractor I should be able to get it to first terrace. From there I should be able to drive out. Fortunately it looks like I have several volunteers to help. I will let you all know next week how it goes. ThanksWait- the tractor is still in the spot?!
What is on top of the hill? Can you get a 4x4 truck or something up there? If so, straps and chains to the top and tug it.
Attach the chains to the bucket (wrap around) and secure any chains with not only the hook, but a bolt or rope wrapped around the hook to hold it in place if the chain goes slack.
Also secure the end to the truck the ssame way.
By pulling from the top of the hill and using the bucket on the tractor you can adjust the leverage from the front to rear tires (bucket higher=lifts rear of tractor and more weight on front and vice-versa).
Make sure you can trust the person at the top. Have at least one or two spotters along the hill and near the tractor. Walkie talkies are good to have, and agree on hand signals ahead of time.
If the truck has to go down the other side of the hill (not sure of your layout there), you can use a log as a rub for the chain, rope, or strap so it doesn't dig into the ground. Just be aware of how much it will rub/wear.
Dang. If you were closer, I'd come by to help. These things can be tricky as it looks like a lot of loose dirt. Whatever you do, be very careful.
Note: recovery work is tricky and dangerous. If you or your helpers don't feel comfortable with it, don't do it. If a buddy has a dozer nearby...
- JC
