I've Decided; X300
/ I've Decided; X300 #1
JDGreenGrass
Maine
John Deere 770
I've all but decided to buy an x300 with a 48 inch deck. I mow about an acre with some rough ground and a few obstacles. I want a tough deck and I have never had hydrostatic drive.
Most of all, I want a mower that will give me years of good service.
Can I expect quality spindles with this mower.??
Is the x300 series the beginning line of a quality mower.??
Have I made a good choice.??
/ I've Decided; X300 #2
Hi JD,
A friend of mine bought the X320 because he wanted the extra ponies to pull a leaf cart in the fall. Upon trading in our 2305 for the 2520 recently and deciding to get a dedicated mowing machine, we ended up with the 4WS X324 as a poor mans alternative to losing the 2305's 4WD for our steep slopes. I drove the X320, then the X324 and was very impressed with the way it handled turning uphill from cross camber over the X320. The 320 would just push the front end out and spin the uphill rear wheel while the 4WS 324 just swung the rear end around and pointed the front end right up the hill. I was sold right there.
In any case, the X300 machines are long lasting quality built machines, at least as compared to the low budget line they are building for the big chain home improvement stores, the LA line of tractors.
The 500 series machines are necessary if you have any plans for gardening with it. You can add a variety of attachments to them, similar to the old 318's and the like.
Isn't it great when you try a product and it talks to you. Sounds like you made a great purchase that fits your needs.
I have no hills to speak of. Mostly flat and a bit of rolling.
You have said what I want to hear. Tired of the run-of-the-mill $1000 riders. The deck on my Craftsmen has a bad spindle, the front wheels are going in opposite directions and the starter isn't engaging the flywheel. Mind you, my yard is in better shape now than it was 3 years ago but, the Sears unit should have stood up better than it has. In other words, my yard isn't so bad that a quality deck can't handle it. I love my grass.
$3000 is a lot of money to put into a mower but, I think the quality of this unit will be worth it in the long run. I am just starting to believe in the theory...buy quality and buy it once.
I visit the dealer tomorrow. They have a good stock of mowers and tractors so it will be a good day, I am sure.:D:thumbsup:
/ I've Decided; X300 #4
Hey again,
My friend who bought the X320 was replacing his 18 year old JD lawn machine (can't remember the model) which was still in fine running condition and sold on CL for around $1000. He just needed the new one for pulling the leaf cart he wanted.
Coming from the 2000 series diesels or your 770, the X300 might be a little bit of a shocking experience. It's a (relatively speaking) loud gas engine and very compact. It doesn't look like you will be able to fit on it but it's fine.
I resisted the X3xx's for a while and was convinced I wanted an X500 machine but when I sat on and drove both of them, they both felt equally compact to me and since it was just going to be for mowing, there was no reason to get the X500. Since the 4WD X7xx machines were out of the selection field, I settled on the X324 for the 4WS.
I hear you on the size. What you are saying is when I sit on the mower you can no longer see the mower.:laughing:
Now this...After using the search function, the tranny is problematic.:confused: Great. Figures that this pops up after I had my mind made up. Un-real. Now I feel like I need to start over from scratch...I'm not sure that I want to invest 3k and have problems down the road.?? The fact remains that the x300 is a solid mower...with a weak tranny.:confused2:
So, I looked to a Husqvarna...guess what...Tuff Torq tranny. I'm not sure that it is the k46.?? Anyone know for sure.??
The Husqy is less money but their website doesn't give much info such as deck thickness.??
I would like to move up to the x320...can't afford another grand.
What is the best mower out there for 3k.??
/ I've Decided; X300 #6
I would still recommend an x320 or better with the k58 transmission, the x300 has the same k46 tranny as the D100 series with hydros. If you don't wan't to spend the extra money for the x320 then consider the D100 with a manual transmission.
/ I've Decided; X300 #7
Look at the Husky Broadmoor models, while these have the TuffTorq transmissions I think these are available iwth the k58 tranny. Might be a savings.
About the deck thickness, while we all wan't a good deck it is meaningless if the mower won't move.
How about Briggs versus a Kawasaki engine.??
The Husqvarna dealer is pointing me to a Briggs engine with a Hydro Gear tranny.
Any thoughts here.??
/ I've Decided; X300 #9
I think all of the engines are decent and seem to last for quite some time. Don't know about the Hydro Gear tranny, can't comment on it.
Trade offs can be hard to work around and in this case the extra money for an x320 is well advised, I would recommend you consider that Deere does offer 0 interest for 12 months. Might be able to make that work to cover the difference in cost.
If all I had to do was mow my own lawn I would have an x320 instead of the x749. I use the x749 in my work so it pays its own way.
Thanks for comments jenkins.
Sounds like the x320 is the mower that has the quality, through and through. I will consider it. I am paying cash but, at 0% over 12 months...it could help with cash flow.
Can I expect the Deere dealer to come down in price...10 to 15%.??
I am now considering either the x300 or the 320 and I am going to look at the Husqvarna machines as well.
Inching towards $4000 makes me shake my head....no.:confused2:
/ I've Decided; X300 #11
Last spring I bought an X300 and I have about 50 hours on it, it is a great tractor. However, at the time I bought it I did not know about the trans issue. In hindsight, if I had known about it I would have spent the extra thousand dollars for the X320. I figure I will probably spend that thousand dollars anyway when it comes time to repair or replace that trans, I guess its like, pay me now or pay me later.
Since the tractor comes with a 4 year warranty I am hoping that if the trans fails during that time I will get it fixed on John Deere's nickel.
/ I've Decided; X300 #12
JDGreenGrass said
Now this...After using the search function, the tranny is problematic. Great. Figures that this pops up after I had my mind made up. Un-real. Now I feel like I need to start over from scratch...I'm not sure that I want to invest 3k and have problems down the road.?? The fact remains that the x300 is a solid mower...with a weak tranny.
I just went through the same decision making process and offer the following for whatever its worth. I bought a new 2520 with a backhoe and didn't want to have to put the backhoe on and off in order to mount a mower deck so I bought a X300 to only mow with. Like you, I have about an acre of flat land to mow and do not plan to add any attachments to the X300.
I couldn't justify spending an extra $1000.00 for a X320 with only a marginally better transaxle. Factors that convinced me to stick with the X300 are as follows:
1. A new X300 comes with a factory 4 year/300 hour warranty and for me that's a lot of mowings.
2. The dealer where I purchased my 2520 and X300 said their 8 stores sold over 100 X300's last year and had to replace one transaxle on a X300. Plus, they said they have not experienced very many transaxle problems with X300's in previous years. Certainly, not more than any other model.
3. If you are mechanically inclined, you can buy the necessary parts and rebuild the transaxle yourself for under $200.00 if you have a problem after the warranty period ends.
4. Based on a review of the archives from this site, there are a lot of X300 owners who said they have had zero problems. Like most things, you usually only hear about the problem ones.
Hope this helps. Good luck with your decision.
/ I've Decided; X300 #13
It's been a little while now, but I believe the Kawi engines are considered to be a considerable upgrade over the Briggs & Stratton.
Because we were also buying the 2520, my dealer chipped off a few bucks from the price of the X324, but it wasn't even enough to cover the sales tax. I don't think JD is in the habit of knocking much off of the prices of these lawn machines. The competition is tough out there and they are doing all they can to stay competitive. Of course, that is just my own observation and could be completely wrong.
/ I've Decided; X300 #14
I purchased a used x320 a month ago from my JD dealer for $3200 out the door. It had 55 hours on it and looked like new. You may want to look for something like this. The dealer talked me out of the x300 and put me in the 320 for about the same price.
So far it has been a great mower. Not super heavy duty like the old ones but pretty solid.
Gio
/ I've Decided; X300 #15
Originally you mentioned the X300 w/ 48". When I was selling them a few years back they didn't offer a 48. Had to go to the 320. Do they now?
Also, I think the "Broadmoor" is a Simplicity which is a good mower, Briggs engine though.
Don't count on the dealer to come down 10-15% That's not far from what he is making. At best I would say no more than a hundred dollars. I usually stayed at the $3999 and 4999.
/ I've Decided; X300 #16
If I were to replace my 165 tomorrow, I'd would purchase the X320. I've researched them and tried them out and wouldn't think twice about the decision. If you make the purchase, you'll have to update us.
Yes, the x300 is available with the 48" deck. Look at the deck at JD.com...the deck is what draws me to x300. Looks a great deck.
I am looking at a 24hp Husqvarna. The dealer can't tell me which tranny is in it.??...I only know that it is a Tuff Torq tranny. And, I want to look at the deck on the Husqy. I need a strong deck.
Over the next 3 days I am going to the dealerships to help decide. The Husqy is less money which is a plus but, I want a mower that is going to last, period. Sure, if money was no issue...I would get the x320, hands down.
We'll see... Any comments on Husqvarna.?? Does HP play a roll in the tranny.?? In other words, the 24hp Husqy may have bigger, better tranny, the K58.
Well folks, I made a purchase today. I bought a Husquvarna GHT27 with a 48"
inch deck.
There is a local Husqy shop that is run by one person, the owner. Great little shop that reminds of the old days. Nice guy. He is about 20 miles closer than the Deere guys so I stopped into the little shop first.
He had 3 Husqy's on his small showroom floor. I began looking at the bigger tractor and my eyes went straight to the deck. I said to myself, wow.!! I was impressed. The lead edge of the deck has a reinforced rim welded on. Super tough. I knew right away it was going to be hard not to buy. Next, I sat on it. Once again...:thumbsup:. Super comfortable with a firm spring action in all directions. The arm rests will have to go but the seat is great. I didn't drive the tractor but the steering felt solid with a great radius for turning. Axle and steering rods were rugged as well. Lifted the hood...Briggs, which I think will be good. 27hp which I really like and at the price I paid...a great value. I have had the Briggs engines before and my smaller engines have always started and performed well. I wanted a Kawasaki engine but, I was so satisfied with all else, it was a fair sacrifice.
Over the phone he said $3000. When I walked through the door he said $2900. I offered $2750 and he agreed.:thumbsup: So, $2750 is less than the $3250+ that I would have paid for the 18hp x300 with an iffy tranny. And, $2750 is a lot less than what I would have paid for the x320, 22hp... like $4000. I think I got a good tractor that looks to be a great mower.
Look for pictures along about tomorrow night. I'll try to post some good close-ups, though I do feel a bit dirty posting them here in the JD forum. I didn't make it to the Deere dealer. I saw a good value and I bought it. One thing is for sure....It doesn't look as nice as the Green and Yellow.:thumbsup:
/ I've Decided; X300 #19
make sure you post a pic when it arrives
Pictures as promised. It's only right that I post the Green first.:thumbsup:
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
UNUSED IRANCH 39" HYD MINI DOZER BLADE (A60432)
UNUSED IRANCH 39"...
(INOP) 2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
(INOP) 2002 FORD...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
