I've Sprung a Spring
   / I've Sprung a Spring #1
EastTexFrank
East Texas, USA
Kubota Grand L4740, B2400 and F2680
I\'ve Sprung a Spring
Last week I was walking around the hay pasture at the farm and I found myself up to my ankles in mud???? I thought that was a bit strange as we haven't had much rain this past month so I started following the water back up the slight slope. I found 3 holes, roughly in a line going up the slope, about 2" in diameter bubbling water at a rate that I would guess to be about a gallon to 2 gallons a minute.
I called the Soil Conservancy people and they said that, yup, it's a spring, probably artesian, and that it might quit on its own and then again, it might not. They did say that if it's left alone it will eventually cut a gully across the pasture to another gully along the fence line that carries the run-off from the stock pond. It might, on the other hand, just turn the bottom part of the hay pasture into a bog. Neither alternative is desirable.
So here is the problem, how do you stop a spring coming to surface or handle the water once it does. Capping it in some way doesn't seem to be feasible, even if it could be done, because it's likely that it will just come to the surface further up the slope. I could run some kind of field drain to collect the water once it's on surface and run it to the stock pond about 100 yards away. There's not much of a gradient from the bottom outlet to the stock pond but it could be done or I could collect it from all 3 outlets and run it to the gully that it's draining into now.
I've never had to handle anything like this before so I'm looking for any ideas. It seems like such a pity to waste such good water but on the other hand I don't want to be water skiing in the hay pasture either.
I'll listen to anything you guys can come up with.
Thanks ... Frank.
   / I've Sprung a Spring #2
Re: I\'ve Sprung a Spring
Bottle it and sell to those city slicker in Houston, Austin, Dallas, El Paso, etc. Who knows, you might become successful enough to give up farming and be in the bottled water business full time..... Just come up with a fancy name like "Natural Prairie Water" /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / I've Sprung a Spring #3
Figure out where you want the spring to go, then use your bottom plow to trench the path you want it to take. On the other hand, there are bottled water companies that'll buy the water from you. /forums/images/graemlins/wink.gif
   / I've Sprung a Spring #4
Don't laugh at Junk's idea. We have a business in this area that's been around for a years called Distillata. You see them delivering water everywhere. Their advertising touts Artesian Spring Water.
It isn't free, Ca-Ching $$$$$
   / I've Sprung a Spring #5
Aahhhggggg... 6 gallons a minute coming out of the ground for free. Throw me in that briar patch.
   / I've Sprung a Spring #6
If you don't want to stop it then I would either ditch it or pipe it to lower ground. That overland flow will bog things up. Here in the NorthWet they would call that a wetland and take your land.
   / I've Sprung a Spring #7
My farm's previous owner just took 1 1/2" crestline tubing (the black plastic water line pipe that comes in 250' coils) and shoved it into those holes where your spring is popping up. Then ran the line to where they wanted the water. I on the other hand find this tubing with my brush hog. /forums/images/graemlins/frown.gif
No fun to untangle.
   / I've Sprung a Spring #8
You need to channel the water anyway before it channels your property. Send it where it will benefit you the most. Remember that what benefits you most might be getting rid of it all together.
With stock I would suppose water is a commodity to have. Send it to the stock pond if you can.
   / I've Sprung a Spring #9
Build a concrete box around the water source. Then run a outlet pipe to where you want it.
I'm not laughing at Junkman's idea at all. In fact it was one of the suggestions from the Soil Conservation people.
"Ozarka" has a water bottling plant about 20 miles away in a little town called Hawkins but they had to drill a well to get their water. Shoot, I'd give them this stuff for free ... well, almost.
If it was only one outlet, I think I'd try to box it in and run a line to the stock pond. But as it is, I'm leaning towards running a field drain just below each of the 3 outlets and combining those into one collection line running to the pond.
On the brighter side, this may be the excuse that finally gets me that backhoe I've been lusting after.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
198367 (A51243)
198367 (A51243)
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2013 John Deere 450J LT (A47477)
2013 John Deere...
