J.D. 70A BACKHOE CYLINDER REPAIR
   / J.D. 70A BACKHOE CYLINDER REPAIR #11
In the first picture, is this what your tractor looks like Curt? If so you have a 855 tractor with a 70a FEL. The second picture is a Deere 770 with a model 7 backhoe.
Is that the backhoe you have?
   / J.D. 70A BACKHOE CYLINDER REPAIR #12
Boy those cylinders on the JD7 hoe look like the ones on my ARPS hoe.
Hi Kenny, those lines have threaded fittings. Thanks , Curt
Hi Irwin,
Yes it looks like the one on the right ! Thanks, Curt
   / J.D. 70A BACKHOE CYLINDER REPAIR #15
Curt,
Do you have the spec's out of the manual for your bucket cylinder?
Piston DIA, stroke, retracted length, pivot pin DIA?
Hi ,
I wanted to thank you guys for all the help. So what happened was , i rebuilt the one swing cylinder on the tractor. I took it apart and found a chunk out of the seal ( that must be the leak ). I replaced all the seals and o-rings. I put it back on the tractor and it started leaking ( what the **** ). Thats when i asked you guys about , if there was sealent around the gland ? To make a long story short, The line that crosses over to the other cylinder is an air passage, i thought it was a fluid line. So when i rebuilt the cylinder , i swung over the hoe arm and what happened then was, the fluid got transferred to the other cylinder ( in the air pocket ). So when i was done i swung the arm over and the fluid came with it and made the side i just worked on leak. So you were right about the sealent ( theres is none ). But in retrospect one side could be leaking and you wouldnt know which side it was, once the fluid gets behind the seals. Im think im a desent mechanic and i was stumped. I hope this story helps someone else with the same mishap ! Thanks , Curt
   / J.D. 70A BACKHOE CYLINDER REPAIR #17
That is interesting, that they would connect the 2 non-fluid sides of the cylinders. That way, no contaminated air gets into the system. If I were you, I would pull that line off and squirt some trally fluid in there, to keep the non-oil side of the cylinder lubricated. Glad you got everything straightened out.
   / J.D. 70A BACKHOE CYLINDER REPAIR #18
Glad you got it fixed;)
   / J.D. 70A BACKHOE CYLINDER REPAIR #19
Isn't that what his problem was? He got oil on the non-oil side and since there is no seal it leaked.
More info coming soon! (A50322)
More info coming...
2016 Ford Explorer AWD Sedan (A55853)
2016 Ford Explorer...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
