Jaunt thru the woods on a Deere (dozer)
   / Jaunt thru the woods on a Deere (dozer) #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
Temps were hitting the 50's last couple of days so I decided to extend a trail I made thru the woods a couple of years ago.
I pick the start & end points, marking the proposed trail 1/2 way hopefully meeting in the middle.
I pick the path of least resistance staying on high ground picking out down trees, stumps & brush. Blade is 6' wide & tracks are 4'.
The dozer floats on the snow & the blade snaps off the small stuff at ground level without ripping up the root ball so there is very little surface damage. Snow cover was 12-18".
Pix 1 the start Are those my footprints or Deer?
pix 2
pix 3
pix 4 this is the only tree that had to go 8-10" dia birch about 30' tall, note the raised blade to get more leverage
pix 5
pix 6
pix 7
pix 8
pix 9
pix 10
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
377811 (A48836)
377811 (A48836)
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2012 Ford Expedition SUV (A50324)
2012 Ford...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
