Unfortunately on my 2009 the front drive shaft roll pins are fine, in many cases they wear and affect the couplers ability to engage the pinion shaft splines resulting in no front wheel drive.
Upon inspection it appears the rear facing 2/3 of the pinion splines are worn/rounded resulting in no front wheel drive. I can remove the roll pin and move the coupler forward and get enough spline bite to get front wheel drive.
So it appears the fix is going to be replacing the pinion shaft HOWEVER the technical service manual indicates the ring and pinion should be replaced as a set and it appears to be a highly technical repair with some specialized tools, or buy the assembly as a unit which is very expensive.
Anyone ever taken on the repair and could offer any wisdom?
