JD 212 Tiller: rear or front mount?
   / JD 212 Tiller: rear or front mount?
Bruce,
Thanks again for the info, you have been very helpful. The gear I was referring to shows up in this thread on a another forum: Weekend Freedom Machines: Tiller model 31 (I'm not sure of the rules regarding linking to another forum -- I apologize to the moderators if I've violated protocol).
I think the tiller is a model 31. I'll have to go back and look at it but it looks very similar.
I'm still wondering what would happen if I did it the way the previous owner did -- do you think I can hook it to the front in place of the snowblower and till a garden in reverse?
Also Bruce -- you are saying that I can somehow hook up the tiller to the back without a lift kit. I'll have to look into that. . . I'm not sure how that would work because as of now the back end of the 212 just has a hitch (i.e. where you would pin a tow behind wagon or a sprayer, etc) and I think the tiller needs a hook up on either side of it, right?
HG
   / JD 212 Tiller: rear or front mount? #12
Unfortunately the model 31 manual is not available online.
Here are a couple of images of the mount from the parts catalog
A lever lift
A cable lift
The 30" tiller that was connected without a lift rod is a different design. It mounts the the frame of the mower on a couple of fancy bolts indicated as number 15. This is a picture of its mount kit
Bruce,
You have been exceptionally helpful, and I thank you.
I have been trying to figure out exactly which tiller I have, but I am having trouble reading the little serial number plate.
Any advice on how I can differentiate between a 30 and 31? (I assume it has to be one of those).
HG
   / JD 212 Tiller: rear or front mount? #14
This is a 31
This is a 30
The mounts and drive systems are different.
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2020 KUBOTA RTV...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
