JD 212 Tiller: rear or front mount?
   / JD 212 Tiller: rear or front mount?
Bruce,
Thanks again for the info, you have been very helpful. The gear I was referring to shows up in this thread on a another forum: Weekend Freedom Machines: Tiller model 31 (I'm not sure of the rules regarding linking to another forum -- I apologize to the moderators if I've violated protocol).
I think the tiller is a model 31. I'll have to go back and look at it but it looks very similar.
I'm still wondering what would happen if I did it the way the previous owner did -- do you think I can hook it to the front in place of the snowblower and till a garden in reverse?
Also Bruce -- you are saying that I can somehow hook up the tiller to the back without a lift kit. I'll have to look into that. . . I'm not sure how that would work because as of now the back end of the 212 just has a hitch (i.e. where you would pin a tow behind wagon or a sprayer, etc) and I think the tiller needs a hook up on either side of it, right?
HG
   / JD 212 Tiller: rear or front mount? #12
Unfortunately the model 31 manual is not available online.
Here are a couple of images of the mount from the parts catalog
A lever lift
A cable lift
The 30" tiller that was connected without a lift rod is a different design. It mounts the the frame of the mower on a couple of fancy bolts indicated as number 15. This is a picture of its mount kit
Bruce,
You have been exceptionally helpful, and I thank you.
I have been trying to figure out exactly which tiller I have, but I am having trouble reading the little serial number plate.
Any advice on how I can differentiate between a 30 and 31? (I assume it has to be one of those).
HG
   / JD 212 Tiller: rear or front mount? #14
This is a 31
This is a 30
The mounts and drive systems are different.
JOHN DEERE 1705/6700 LOT IDENTIFIER 20 (A53084)
JOHN DEERE...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
