jd 214 engine stops when mower clicks in
   / jd 214 engine stops when mower clicks in
will try another battery thursday, have to fish tomorrow.
Jd it looks like you have already cover this but my Cub was doing that and it ended up to be nothing more than a low battery. Those electric clutches pull a load that can do that without a good battery.
MarkV
mark, just went out and tried a new truck battery with 1150- ca and it did the same thing, i cant find the circut breaket in the wiring, supposed to be one between pto and ammeter??? i have a wiring illustration, thnx cy
Meaning no wires connected to the clutch....or meaning the clutch is not connected to the mower deck?
Do you have a wiring diagram?
yes i have a wiring diagram, wiring is unplugged from clutch but clutch is still hooked up to mower re belt.
i an going to remove rear fender seat etc, and check all the wires i can find nd check for a short, will be back.
all repaired, thnx to everyone for the help, problem was the wiring for the disconnected seat safety switch, thnx again
   / jd 214 engine stops when mower clicks in #26
Glad you got it figured out. It is always the small things it seems.
MarkV
i mite add, for those that do not know and have series john deere 200 and up try this webb for info littlereentractor .com excellent webb. jd214
sorry that shud read littlegreentractor.com
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
