jd 214t baler
   / jd 214t baler
the site i ordered the bt130 from said it was for small square bales guess not. the stuff in it when i got it only said 9000 feet.
**** if this don't work ill order some 1/4 inch pull rope
   / jd 214t baler #22
No need to get radical yet. It is a little difficult to help with this stuff from one coast to the other. If you were near by, we could likely get you squared away in just a few hours, but we will do the best we can with what we have to work with.
If you want, mail me the 130 and I can use it in my round baler. Or maybe some one in your area has a round baler who can use it.
I thought the sisal was usually 9000. Do not get to discouraged, you have people here willing to set straight what the sales men mess up. Good twine is not that hard to come by. Around here the big "farm" store is TSC or Tractor Supply Co. They carry sisal small square, plastic round bale and plastic big square. I have never seen them to carry the plastic small square, but I digress. Good twine should not be that hard to come by, a box of 170-9600 should do 500 plus bales unless you are making them really small.
Were the bill hooks holding the thin 130? If so you may be fine to use 170 knot strength plastic. It usually comes in 7200 or 9600 balls. But your baler was never built when plastic twine was even conceived yet. Probably best to get everything working right with the sisal, and then you can try the plastic after you know the knotters are working properly.
   / jd 214t baler
oh it takes alot for me to get discouraged. i think this is just amazing how so many things can all work in harmony. the hooks seemed to be holding it fine. to get to a tsc it takes a 6 hour drive to bakersfield fun field trip just costly so i get to order everything online. 2 hour drive to the closest place i know of to get twine. and round balers are nonexistent here they would not know hoe to move them. i wish i could find them here, the best we can do is the dairy 3x3x8 footers
   / jd 214t baler #24
If they are holding the 130 fine then you can probably use plastic. Plastic has always given me better results anyway.
Have you adjusted the wipers yet and sharpened the twine knife?
   / jd 214t baler
yes tightened and sharpened the knives they cut real clean. before i adjusted the wiper it would not completely take the knot off,after the needle twine seem ti not be entering the twine disc but i really haven't had a chance to check that out so im holding judgement until i get the new shear bolt in.. also how thght should the shear bolt be tightened to? could not find that in the book.
   / jd 214t baler #26
As to needle twine into twine disc. The clearance between the needle and the top edge of the twine disc should be really really small, just barely clearing. The adjustment for this is on the needle lift arm. There are two bolt holding the needle to the arm. You will see how if you loosen the bottom and tighten the top it will draw the needle closer down, or the opposite if it is actually hitting the twine disc. You may need to remove the needle to loosen up the bolts and get them adjusting properly, use never sieze, the farmers best friend. Also make sure the needle just barley contacts the right side of the knotter frame. If the needle is too high, you will miss tye. (Had this happen to me a few years back, but was able to adjust and keep going in the field.) If you have to adjust the needle down, recheck the clearance on the tucker fingers. They too should just barely clear the needle when the come across the face of it.
No real spec on the shear bolt tightness. It should be a locking nut that comes with it. Just good and snug will do. Don't crank the day lights out of it.
   / jd 214t baler
cool thanks, on thusrday im going to do a photo essay on all the adjustments ive done so far. i have the needle's within specs, but will photo to make sure
   / jd 214t baler #28
looking forward to pics, do the best you can for these hold eyes do not see a clearly as they used to.
   / jd 214t baler
ok today i got the shear bolts and the sisal twine. got it all put together and checked the tensions. fired it up and both knots still were hanging up so i polished the bill hook a little. the left one would now drop the knot but the needle twine would not tie,so i un adjusted the tucker finger to close to where it was before i started messing with it. the right one still would not drop the knot on inspection the pivot pin on the tongue area was cracked, luckly when i got my sickle mower he gave me a tone of extra parts for the mower and i had a brand new bill hook in the bucket. i put it on and now left is knotting pretty well 9 out of 10 and the right in 0 out of 10. i think im gonna try to un adjust the tucker finger tomorrow. the bale side is making a knot but the needle side is just sitting inside the other knot
   / jd 214t baler
pics hopfully
   / jd 214t baler
ok where to start... i baled @70 bales today hand tied the right side about 80 % of the time it seems like its tying fine but something in the either the wiper arm or the bill hook isnt letting it go? i found if after it ties i can push the string to the right to dislodge it. but if i just pull the string out it unties the bottom knot. i have some pics but my cat's got in a fight and knocked my computer off the table and killed it. so im using my kids netbook and havent figgered out how to resize yet...no wait i figgered it out!!!
   / jd 214t baler #32
Have adjusted the wiper, and sharpened the twine knife on the right knotter???
   / jd 214t baler
they are sharp and i did some adjusting but it looks to me like it isnt returning to the right side of its stroke far enough i am re reading that section of the manual as soon as i get a break at work today
   / jd 214t baler #34
Your adjustment of the needle to the twine disc looks right on.
On the end of the wiper that goes into the cam, there is a ball on the end that actually comes in contact with the cam. If that ball is there, you pretty much have all the movement you are going to have. If it is missing, this could be part of problem. Wiper would not return far enough, and would not move far enough when wiping. If that is missing, you may need to replace wiper, or replace the ball. I have never had to do this on any of the balers I have ever worked on, but it is possible this could be the problem
If this comes through. this is a link to JD parts page of the type of knotter you have. It is actually out of the 224t book, but will show the ball I am talking about on the top end of the wiper that goes into the big cam.
Error java.lang.NullPointerException
Says error, but when I just clicked it to check it, the page came right up. Try it anyway and see if it does for you also.
No mater how sloppy one of these is, I have never seen it stop a knotter from working. If the knots on that right side are still hanging up, I am still looking at how tight the wiper is. Until it takes a pull of about 10-15 pounds, they are not tight enough. The twine you have in there looks good for what you are doing. I like the length of the little shreads that are falling out of the left knotter. I do not see any for the right knotter?????
Did you remove the flat springs for the twine disc tension, to make sure that they are not stuck together? Maybe even loosen that right side up a little more. You can all ways tighten back up if needed. Also look at that right twine disc and make sure it is turning properly. Judging by the top right picture from 4-29, that is the classic look of the twine not being cut properly. If the knife is not sharp, it puts a hard pull on the twine and can really tighten it up around the bill hook.
Minor point, not the problem here I don't think, but tucker finger adjustments. They should almost touch the needle as they start moving across the face of the needle. Spacing becomes more critical as you crank more hay through the baler. This adjustment though is not causing the knots to hang on the bill hook. Two main things do that, wiper adjustment, and knife sharpness. Make sure you are 100% on these items, and the ball is on the cam end of the wiper, before you even think about doing anything else with the wiper travel.
Let me know what you find. When you hear hoof beats, think horses not zebras. Not enough wiper travel can be a real zebra answer. We need to eliminate at the horse answers first.
   / jd 214t baler
the ball is there ill look into the wiper more i did take off the flat springs and wire wheeled them put some anti sieze and reinstalled, also today i took out the right hand side disk holder and twine disk. the gear on top has some play in it and the pin is real loose. any thoughts on that? i found some knives in the bucket of stuff the guy gave me i might put them on i do have the knife pretty sharp. here is some pics of the tucker finger when i adjusted it to the book the left stopped knotting i put it back to where it was and it started knotting again. I have started to get more to knot on the right side having them adjusted the way it is now...take a look and lemme know. and Barry thank you for spending so much time helping me with this i'm learning alot and still enjoying the learning, although my hands still hurt from tying all those bales!
   / jd 214t baler
ok here is the wiper does it kinda look "normal" i think it is still kinda loose. i rubs with pressure but not 10-15 lbs pressure the tip is rubbing but like 2-3
   / jd 214t baler #37
With out actually holding it to look at, that does not strick me as being anything majorly wrong there. It looks pretty good. The pictures you send of the twine hanging on the bill hook is classic, I say classic, loose wiper and or dull knife. While you have it out, clamp it in a vice and give the wiper a good hammer blow. Work it back in and see if tight enough or if it needs more. Personally I like to sharpen the knives with a file, but wear gloves in case you slip. Rough sharpen with good file, and finish with fine sand paper. If you replace then, I have bolted then on instead of rivets. The ones I have done, a 1/4-28 thread worked just right to tap into hole. Becarefull not to long on bolt to get in way else where. JD did go to bolting on when they got into the 336's. It will make sharpening later much easier also.
The actual twine disc should not be loose. The disc cleaner that fits into the twine disc is loose naturally. The tensioner that goes into disc on the spring side hangs loose when no twine, but tight when loaded. If loose, maybe during tying, it holds twine tooooo tight???maybe?? You may need to determine if the shaft, or the knotter frame is worn to determine where to go from here. The twine disc and gear should still be available, but lets make sure that is the problem before we spend money. Maybe try switching up the twine discs and gears and see what you get to see if it is the knotter frame being warn or what. For older balers like this, see if there is a grave yard some where in UPS range. I have been able to buy complete knotters this way for like 100. The twine disc and gear will likely cost this or more. Some times these old balers got parked, because the people working on them just could not get it perfect or even close to right, but we will keep trying.
As to the tucker fingers, if you had a spot that was working well, stay with it. Older models like this do not have the same exact adjustments that the 24t and new have where the tucker is on a plate and moves forward and back for adjustment to the needle face. When this gets more critical is when you are really packing the hay to it.
How heavy and long are your bales coming out. Ideal is about 36-42 inches, 12-16 strokes at around 3 inches or a little less, and 35-45 pounds for standard size. Is the 214t standard size or the larger small square, not sure? If larger small square, a little heavier. Really loose bales will create as many problems as really really tight ones. Your OM should have a chart in it for looking at knotter problems and what the actual knots can tell you is wrong. This can be very usefull. The twine coming out of the twine box should only take a very light pull, a few pounds at most. There is plenty of restriction in the rest of the way to the knotters to keep things tight.
I am still at classic, wiper loose, twin disc too tight, or dull knife from the last picture of the twine hanging on the bill hook.
   / jd 214t baler
well today i was playing with the wiper and was cutting some twine with it then i tried it with the new knife and realized i guess i didnt get the old knives very sharp! ill put the new ones on and give it a whirl. Barry when you tapped it did you use hex head bolts or machine screws?
   / jd 214t baler #39
I used hex head 1/4-28 since it was a little smaller than 1/4 rivet. When JD did it, they used something small and metric as it takes an 8mm wrench. Since JD does it, I figured why couldn't I do it sort of the same way, but I do not own a metric tap and die set. So, I worked with what I have. Also when JD did this with the knives, they also did it with the wiper. Look up the knotters for say a 348 and you will see what I mean. I have not been able to figure out how to convert the old style wiper to the newer style with the adjustable wiper surface where you do not have to actually bend the wiper arm. Please let me know how it works out.
   / jd 214t baler
will do, i looked on the deere site for a 336 baler and saw what you mean with the bolt on knife and wiper. gonna be a few days till i can work on it again.
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
