deerslayer6
I have a john deere 2305 that will fire and run for about 2 sec and quit. I believe it is a fuel problem, but can't pinpoint it. I have changed the filter, pushed the primer lever a 1000 times, disconected the fuel line in front of the injectors to try and bleed them with no luck. Manuel says the lines bleed automatic. I used the tractor and it was running fine then I parked it and when I went to use it again this is what happened. Ant help would be greatly appreciated. I am thinking I need a new fuel pump.
