JD 2520 Sloppy FEL Handle!
   / JD 2520 Sloppy FEL Handle! #1
Deadman
Veteran Member
WI
John Deere 2520, X475
My 2520 has a real sloppy feel to its FEL Handle. Its not a huge deal, but its annoying when you try and do precision work with it because you need to move it past all the "slop" before it starts activating the next control. The handle on mine slops mostly side to side in the curling position, and I'm wondering if there is any way to eliminate that?
I ripped it all apart this week and adjusted the adjusters at the bottom on the lever and its reallly not much better!
Any suggestions?
Thanks in advance!
Any suggestions?
Thanks in advance!
Anyone?
   / JD 2520 Sloppy FEL Handle! #3
Your valve is probably not that sloppy.
If it is cable operated, that is the most likely cause.
Inspect all the parts for looseness and replace/repair.
Look at the hole in the spool shaft also.
Its all turnbuckle adjuster and push rods. They are not worn, just all kinds of slack in them. I adjusted everything I could and all it really did was change the location of the FEL handle. Hmmmm
   / JD 2520 Sloppy FEL Handle! #5
My 4110 is the same, I just learned to live with it. The only cure I know would be to custom machine bushings for all the linkage pivots rather than just having a pin through a punched hole.
   / JD 2520 Sloppy FEL Handle! #6
Mine is the same, it bothered me at first but now that I am used to it, I don't mind.
dang, was hoping to snug it up!
   / JD 2520 Sloppy FEL Handle! #8
Yeah, have the same complaint about mine. Tried to tighten it up, and even put some spacers in it with no Improvement. Its just not made with very tight tolerances.
Might be able to take it apart and drill the holes out. Then put bigger pins it that fit snug. That's what guys do on bigger machines.
2025 PURE LT-C727.2+2 Electric Golf Cart (A44572)
2025 PURE...
John Deere 6105E (A46443)
John Deere 6105E...
STORAGE FEES (A43005)
2016 Chevrolet Traverse 2LT SUV (A44572)
2016 Chevrolet...
2020 Rawmaxx XCH-40-210K 40ft 20,000lb T/A Gooseneck Trailer (A45336)
2020 Rawmaxx...
2019 MACK PI64T TANDEM AXLE SLEEPER (A43005)
2019 MACK PI64T...
