JD 2720 Question
   / JD 2720 Question #1
stablerock
Morgantown, WV
JD 2720
Hi all, I'm new to the forum and have several questions that hopefully someone will have the answers to.
Not sure what it's called....but on a JD 2720 and maybe other similar models as well, there is an adjustment knob directly in the middle between your legs on the floor.
I know its some sort of hydraulic adjustment....and can be adjusted from "fast to slow" etc., but unsure exactly what it's function is and how it affects hydraulic performance.
I think it slows down the hydraulics some so your attachments are not so quick and jerky, but does it also reduce the hydraulics power ?
Can it be adjusted to make the 46 backhoe attachment more smooth...and less fast and jerky, without reducing the digging power/force ?
I'm considering a used 2720 and would like some more info before I pull the trigger.
Thanks Jeff
   / JD 2720 Question #2
Answered in the JD forum...
   / JD 2720 Question #3
Thanks Jeff
Jeff it only slows the lift and fall of the three point hitch so you don't slam your three point attachments like Bush Hogs on the ground . very gentle turns allows you to ease them down . Hope this answers your question
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2007 JLG 41AM DC Electric Vertical Mast Lift (A50322)
2007 JLG 41AM DC...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
