JD 3046r tractor won't start, nothing has power when turn key, occasional clicking of relay under dash
   / JD 3046r tractor won't start, nothing has power when turn key, occasional clicking of relay under dash #11
I had basically a "rotten" battery positive cable end along with a couple inches of copper cable under the insulation. It looked "good enough" until I cut back some the insulation and that looked quite bad! I wonder if the battery clamp had some sort of impurities causing a galvanic corrosion with the copper? Anyways, cutting back to good wire and new clamp got it starting like new again.
Hello all, I greatly appreciate your feedback and help.
I ended up testing using the multimeter at different locations starting from the battery. I would cycle the key on/off and do a reading, 12.8 everywhere on both until I got back to the place where the hot connects to a plate and then jumps to a bunch of smaller hots (to run to alternator, starter, etc.). I read the hot lead and the bolt and then the plate and the plate read 3.8v.
With that, I pulled the lead off, wire brushed it, applied dielectric grease and reconnected and voila, it was back up and running. Turned out being pretty simple once I started stepping back from the battery to determine where the power loss was.
Thanks so much!
   / JD 3046r tractor won't start, nothing has power when turn key, occasional clicking of relay under dash #13
Good deal, thanks for coming back and telling us what was wrong.
   / JD 3046r tractor won't start, nothing has power when turn key, occasional clicking of relay under dash #14
Thanks so much!
MikeStern I have a question. Before it quit trying to start entirely did it do some funky things, like engage the starter for a split second every second or so for a few times before finally cranking over, also give you a ECU code 1458.02 "ECU main relay data erratic, intermittent or incorrect"?
TUGGER TRAILER (A55745)
TUGGER TRAILER...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
377789 (A51573)
377789 (A51573)
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
