JD 325 lawn tractor won't stay running
   / JD 325 lawn tractor won't stay running #1
JFrost
FRANKFORT
325 John Deere
Please help. I can't keep my JD 325 running. It will start with full choke but if you let off the choke it will stall. Have change fuel, fuel filter, fuel pump and spark plugs.
   / JD 325 lawn tractor won't stay running #2
Welcome. You'll definitely get some suggestions here...
Water in carb bowl. Tank plugged with 'stuff'. Tank vent plugged ?Fuel pickup hose in tank is cracked, leaks and otherwise NFG.
Can you run a gravity feed line directly from a fuel supply to the motor ?
Can you back flush the fule line with a shot of compressed air as a temporary fix ?
Can you dribble gas into the air intake to see if it runs continuously or is it not a fuel problem ?
If the fuel filter is clear plastic, can you see fuel in it ?
It is getting fuel.
   / JD 325 lawn tractor won't stay running #4
Also make sure the fuel solenoid on the bottom of the carb is clicking when you turn the key on and off. Just went through that on a customers mower a couple months ago, that would do the same thing. run with choke on ,but would die as soon as choke opened.
will check, thanks
having trouble figuring out part no. for the solenoid. There are two different nos. that I come up with on the John Deere websight. I don't know if I have the FH531V model or the FC540V model. How can I tell?
   / JD 325 lawn tractor won't stay running #7
Should say on the name plate on the motor somewhere IF the label hasn't fallen off or if silk screened fade so it can't be read.
The engine is Kawasaki and its no. is 4kax4942ca 494cc (0.49L) and the ID no. is M00325B087318 which doesn't tell me if it is the FH531V or the FC540V. so that is why I am stuck.
so I ordered what I think is right. Will let you know if it solves the problem. Thanks for everyone's help.
   / JD 325 lawn tractor won't stay running #10
Does your fuel solenoid have a rubber tip? If so, remove it and see if that solves your problem. Fuel solenoids can be expensive and this is a good way to verify that it is faulty before ordering a new one.
2015 FORD E-350 14 PASSENGER VAN (A52472)
2015 FORD E-350 14...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2020 KUBOTA RTV...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
