JD 350 Sickle Bar Mower?
   / JD 350 Sickle Bar Mower? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I found a John Deere 350 sickle bar mower with a 7' bar for sale locally. The seller wants $1500 obo. Is this a good sickle? I want something that can do extreme angles as I have this fantasy of using it to prune the brush along the side of my driveway. Is this size acceptable for my L39?
ac
   / JD 350 Sickle Bar Mower? #3
Depends on what shape it's in.
When I paid $500 for my 9ft 350 mower I thought I'd done well. Until the next year when I had to rebuild the "wobble box". That repair alone was over $500 in parts. Had to replace all the knife sections, wear plates and hold downs this year. Another $200.
If you can, listen to it run so you can pay close attention to the wobble box. Listen for any hard knocking or grinding. Those things would indicate bearings failing. Check the knife sections, wear plates and hold downs for wear as well.
Hope this helps.
Mark
   / JD 350 Sickle Bar Mower? #4
Your tractor is plenty big for the JD350. I had a 9' 350 on a Kubota L2900 and it works okay; I would not want to use a smaller tractor, but your L39 is much larger. The issue is not power, but weight. I now run the 9' on a Kubota B2400 with 18 pto hp and it does not even load the engine. But the heavy bar and wobble head are offset a foot or two beyond the right hand lift arm of your TPH and it takes the substantial tph of a 2,500 to 3,000 pound or more tractor to manage the offset weight. When I moved mine to the B2400 I built a frame that hooks to the rear axle housings and FEL brackets (like a backhoe frame) to hold the mower because the little B2400 tph was clearly too lightly built.
I agree with Mark; the wobble head can be very expensive to repair. To check it out, let it run slowly while you pour lots of oil on the knife (the thing that holds the triangular cutters or "sections") so they are quiet for a few seconds. The knocking may just be the 1" or so diameter drive pin that connects the reciprocating arm in the wobble head to the knife head; that pin and the needle bearings in the knife head are not too costly ($75). You can tell if the pin is loose by slowly turning the flywheel back and forth a few degrees while you place your fingers along the joint between the reciprocating arm and the knife head; if you feel motion the pin is worn. But if the knocking comes from inside the wobble head you will be lucky if it is only the bearings and not the several hundred Dollar crankshaft or related parts; I probably would not buy it with such noise.
It will cut the brush along the sides of your driveway as you mention, but you will have to rig up some linkage to hold the cutterbar vertical and to keep the whole wobble head and cutter bar assembly from bouncing up and down on the spring. Mine will cut 1" brush if you go slow, but I try to limit that sort of cutting because it dulls the sections and the noise from the machine suggests it doesn't like it.
I bought a second JD 350 with a 7" cutterbar that I am rigging up to put on the fel of a 40+ hp tractor with a hydraulic drive to cut banks and the sides of driveways. But that project is just in the planning stage.
I think I paid about $1,800 for each 350 and they turned out to be in pretty good mechanical shape. After a year I replaced the knife and rock guards (the pointy things that the knife sections reciprocate in to cut the grass) with a complete system from Schumacher that is used on many grain combines. It has roller guides rather that wear plates and hold downs, and I am very satisfied with it.
Let us know how it turns out.
   / JD 350 Sickle Bar Mower? #5
I admit that after I got my 350 home and hooked to my 1720 (28hp 4wd) that I was greatly disappointed .... at first.
The good thing about the 350 JD is that it can be set in a wide or narrow position to accomodate a variety of tractors. Once I got mine set to the narrow stance my Tractor handled it much better and I quickly got over my initial disappointment.
When I get back to my office tomorrow I'll post a link to another forum that has a real expert on these mowers and a great post that helped me a lot.
Any chance anyone has the manual in .pdf for this mower? I'd love to review the manual before purchasing to get an idea what I am getting into.
ac
   / JD 350 Sickle Bar Mower? #7
A lot of good information on what to look for when buying one of these mowers is in this thread.
JD 350 sickle mower
Do some searching at that site and you can find all sorts of information on these mowers.
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
1995 Rinker Captiva 190 (A55302)
1995 Rinker...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Portable Restroom (A54865)
Portable Restroom...
Forklift Safety Basket Attachment (A55787)
Forklift Safety...
