JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #11
There is an electronic throttle control mounted on the motor on all the machines. If there is no e throttle option, what purpose does it serve? From my understanding, load match regulates transmission speed
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #12
Yes, that is the way Load Match on my 2007 3720 and 2010 4320 functions. Newer machines may be different.
So would that mean that eThrottle/AutoThrottle should be available on all machines? Dealer said that the eThrottle is ONLY available on the AutoHST not the eHydro... sounds... IDK.. ??
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #14
Dealer may be wrong, as mine is. According to all other sources than them -including TractorData- ALL 4720's with eHydro have eThrottle and many other 3x20 and 4x20 have it too. However JD themselves don't make this very clear and, at least in the 4720, you won't find any eThrottle switch anywhere and the manual never mentions it by name. This feature appears to be concealed within the depths of the rather confusing cruise control options and somewhat interfaced with one -or more- of the "Match" systems the use of which, apart from MotionMatch, is still unclear to me even after 8 years of ownership. I find my 5105M much simpler to operate despite having a lot more controls. I would appreciate if someone could tell me in non-rocket scientist terms how this eThrottle thing is enabled on its own. By that I mean not having to set 17 other features in motion in order to get at it. The manual is useless on this and as for my dealer he says "eThrottle is for yard tractors I think, some have that switch". In other words he doesn't know jack sh.. about it.
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #15
the e-throttle works as such: when you push the hydro peddle in forward or reverse, it raises rpms like you were driving a car. almost works like the power reverser trans. But as already mentioned, only available in the 4thousand twenty series tractor.
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #16
Karl, on the 4520 and 4720 equipped with the upgraded cruise swithches you get a separate switch to turn off/on the auto throttle function. Seems I remember that when installing the upgrade that you remove the existing cruise switch and it is replaced with three other switches. If you don't have the upgraded switches you may not be able to use the auto throttle function. It is a good feature and I use it most of the time except for things such as tilling or brush mowing where a constant pto speed is more desirable.
   / JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #17
eThrottle (auto throttle) is standard equipment on 4520's and 4720's only. It doesn't matter which cruise control you have, as long as all the switches have a place. I'm not sure what year the option became available though. I surmised that it was when the engine HP jumped up and became all electronically governed (maybe 2009???). The new operators manual DOES mention it.
As does the service manual. I don't buy into the notion that the feature exists on "all 4x20's with eHydro", and that it just has to be "enabled".
I've attached the schematic from my service manual. It shows where the switch goes, in case someone wants to experiment.
It is a great feature that, to me, is needed to really make the "LoadMatch" feature shine.
  • ethrottle.pdf
1612 (A58375)
1612 (A58375)
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Army Generator (A57454)
Army Generator...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
