sunnyside360
Veteran Member
- Joined
- Aug 8, 2006
- Messages
- 1,561
- Location
- Central PA
- Tractor
- JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
I have a 3720 cab tractor and a 4320 open station tractor along with 3 rotary cutters --- two 5' cutters and one 6' cutter. I've only had the 6 footer on the 3720 a couple of times and the front was very tippy on the hills due to additional RC weight and it works the engine more in heavy grass. So I just use the 6 footer on the 4320 in the heavy stuff and on steeper hills, and use the 3720 on flatter light/medium density grass.
Bottom line based on my experience is you'd be okay with the 6' rotary cutter on flatter terrain and light/medium density grass. You'd be happier with the 5 footer when on hilly terrain and/or heavy grass. Also, if time is a factor, you will be able to go a little faster with the 5 footer and offset the width advantage of the 6 footer.
