JD 3720 Tractor, mid mount mower or 3 Pt Finish Mower?
   / JD 3720 Tractor, mid mount mower or 3 Pt Finish Mower? #11
Having had both I'd go with the RFM for wide open spaces and the mid mount if you need real control. I have a 72" quick connect for my 3520. The only thing I don't like about it is it doesn't raise more than 3" off the ground. I put it on to mow and remove it immediately after. Really in the way for all other tractor uses.
Right on. I have a 3720 with 72 inch mmm and while it works great I have to remove it to do almost anything else because the deck is only 2-3 inches off the ground when not using it.
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2011 FORD F-450 (A52472)
2011 FORD F-450...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
